I have a room with 15 pc sometimes 1 or 2 pc give error -4.132.0
From log
10:16:42 (adskflex) IN: "79700EMS_F" tecnichecad@PC3
10:16:42 (adskflex) IN: "85626EMS_2011_0F" tecnichecad@PC3
10:16:52 (adskflex) OUT: "79700EMS_F" tecnichecad@PC2
10:16:52 (adskflex) OUT: "85626EMS_2011_0F" tecnichecad@PC2
10:16:52 (adskflex) DENIED: "79700EMS_F" tecnichecad@PC3 (Licensed number of users already reached. (-4,342))
10:16:52 (adskflex) DENIED: "85626EMS_2011_0F" tecnichecad@PC3 (Licensed number of users already reached. (-4,342))
but in PC3 no program of autodesk is open.
Solved by TravisNave. Go to Solution.
It looks like you are running out of licenses.
If you run license server status enquiry you can find out how many licenses are checked out from your server at the time you receive the error.
1.open lmtools window (Start > Programs > Autodesk > Network license manager > Lmtools Utility).
2.Then lmtools > Server Status > Perform Status Enquiry
Avto
Status
Flexible License Manager status on Tue 1/29/2013 11:53
[Detecting lmgrd processes...]
License server status: 27000@dmn01
License file(s) on dmn01: C:\Program Files\Autodesk Network License Manager\license\EMS2011itlicense.lic:
dmn01: license server UP (MASTER) v11.7
Vendor daemon status (on dmn01):
adskflex: UP v11.7
Feature usage info:
Users of 79700EMS_F: (Total of 14 licenses issued; Total of 14 licenses in use)
"79700EMS_F" v1.000, vendor: adskflex
floating license
rd PCDOCENTE PCDOCENTE (v1.000) (dmn01/27000 1611), start Tue 1/29 8:41
tecnichecad PC7 PC7 (v1.000) (dmn01/27000 416), start Tue 1/29 8:39
tecnichecad PC11 PC11 (v1.000) (dmn01/27000 2510), start Tue 1/29 8:41
tecnichecad pc8 pc8 (v1.000) (dmn01/27000 610), start Tue 1/29 8:38
tecnichecad PC14 PC14 (v1.000) (dmn01/27000 2013), start Tue 1/29 8:38
tecnichecad PC13 PC13 (v1.000) (dmn01/27000 110), start Tue 1/29 8:42
tecnichecad PC1 PC1 (v1.000) (dmn01/27000 1711), start Tue 1/29 8:47
tecnichecad PC9 PC9 (v1.000) (dmn01/27000 2111), start Tue 1/29 8:49
tecnichecad PC12 PC12 (v1.000) (dmn01/27000 2711), start Tue 1/29 8:50
tecnichecad PC4 PC4 (v1.000) (dmn01/27000 2910), start Tue 1/29 8:51
tecnichecad PC10 PC10 (v1.000) (dmn01/27000 1116), start Tue 1/29 8:54
tecnichecad PC2 PC2 (v1.000) (dmn01/27000 3111), start Tue 1/29 10:16
tecnichecad PC5 PC5 (v1.000) (dmn01/27000 1414), start Tue 1/29 10:27
tecnichecad PC6 PC6 (v1.000) (dmn01/27000 2417), start Tue 1/29 11:42
Users of 85626EMS_2011_0F: (Total of 14 licenses issued; Total of 14 licenses in use)
"85626EMS_2011_0F" v1.000, vendor: adskflex
floating license
rd PCDOCENTE PCDOCENTE (v1.0) (dmn01/27000 1511), start Tue 1/29 8:41
tecnichecad PC7 PC7 (v1.0) (dmn01/27000 316), start Tue 1/29 8:39
tecnichecad PC11 PC11 (v1.0) (dmn01/27000 2610), start Tue 1/29 8:41
tecnichecad pc8 pc8 (v1.0) (dmn01/27000 510), start Tue 1/29 8:38
tecnichecad PC14 PC14 (v1.0) (dmn01/27000 1913), start Tue 1/29 8:38
tecnichecad PC13 PC13 (v1.0) (dmn01/27000 210), start Tue 1/29 8:42
tecnichecad PC1 PC1 (v1.0) (dmn01/27000 1811), start Tue 1/29 8:47
tecnichecad PC9 PC9 (v1.0) (dmn01/27000 2211), start Tue 1/29 8:49
tecnichecad PC12 PC12 (v1.0) (dmn01/27000 2811), start Tue 1/29 8:50
tecnichecad PC4 PC4 (v1.0) (dmn01/27000 3010), start Tue 1/29 8:51
tecnichecad PC10 PC10 (v1.0) (dmn01/27000 1216), start Tue 1/29 8:54
tecnichecad PC2 PC2 (v1.0) (dmn01/27000 3211), start Tue 1/29 10:16
tecnichecad PC5 PC5 (v1.0) (dmn01/27000 1314), start Tue 1/29 10:27
tecnichecad PC6 PC6 (v1.0) (dmn01/27000 2317), start Tue 1/29 11:42
Users of 79600EMS_2010_0F: (Total of 14 licenses issued; Total of 0 licenses in use)
The status is clear. You are out of licenses. Thus the -4 denial error. You need to either purchase more licenses for the number of users that need the Autodesk product, or you need to better coordinate with your users not to open a license and keep it all day.
You could implement a TIMEOUTALL option that will release an unused idle license if the user has the program open but is not using it all day. See my adskflex.opt options file link in my signature for more information.
