Installation & Licensing
File Corrupted Error w/ Autodesk Self-Extractor
6 REPLIES 6
eliasbaldwin
2307 Views, 6 Replies
I have spend the last couple of days trying to install the student licenced AutoCAD 2015. The Install Now program never worked for me (I could never get past having a communication error despite spending many hours troubleshooting), so I decided to use the browser download option. After an hour of downloading (and that's with pretty quick internet) I ran the installer.
After two seconds I got this popup:
I'm rather dissapointed that after all of that time downloading I can't even install the software.
I've even downloaded and installed other 2015 Autodesk software using the same browser download method and it's worked fine.
It is a real pain not to be able to install this program after downloading a 1.6 GB file.
6 REPLIES 6
TravisNave
in reply to: eliasbaldwin
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
It usually works better.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
pabloe1177
in reply to: TravisNave
I am having the say problem even though I used the virtual assistant. PLEASE HELP.
EvilMelky
I am having the same issue. Please Help!!
pete_gumby
Also used Virtual Assistant
Downloaded a 2.4 gig file for REVIT 2015 and I get the same error message from Auto Desk Self Extract
Corrupted error
HELP!!!
Mark.Lancaster
in reply to: pete_gumby
@pete_gumby
I have seen this before..  Not sure what is causing the issue but try a different browser and/or machine to download from the Virtual Agent.  I had one computer that I was downloading on and kept getting the same message.  When I switched to another machine it downloaded and extracted just fine.
Mark Lancaster
TravisNave
Mark is right.  Try a different browser and make sure that your anti-virus is disabled during download.
Autodesk Forums:
Administrator Productivity
