Installation & Licensing
Fetch Feature License inforamtion with variable FLEXLM_DIAGNOSTICS
1 REPLY 1
mbathala
361 Views, 1 Reply
I have AutoDesk Inventor 2013 Installed on my machine.
I need to figure out what are the Feature Licenses that Inventor fetches when an assembly or drawing in opened in it.
I used system env variable FLEXLM_DIAGNOSTICS = 3 for this purpose.
I can see the flex log is getting creatind in "installation/bin" folder.
But the log is ampty and gives no information on Licenses.
How do I fetch such License information otherwise?
1 REPLY 1
TravisNave
in reply to: mbathala
You can perform a status enquiry from the server status tab of LMTOOLS.  It will show you exactly which feature is checked out to you.  The debug log should also show the OUT feature to your username/computername.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
