Installation & Licensing
Active Member
0 Kudos
Post 1 of 2
Fetch Feature License inforamtion with variable FLEXLM_DIAGNOSTICS
136 Views, 1 Replies
03-25-2013 09:47 PM
I have AutoDesk Inventor 2013 Installed on my machine.
I need to figure out what are the Feature Licenses that Inventor fetches when an assembly or drawing in opened in it.
I used system env variable FLEXLM_DIAGNOSTICS = 3 for this purpose.
I can see the flex log is getting creatind in "installation/bin" folder.
But the log is ampty and gives no information on Licenses.
How do I fetch such License information otherwise?
893 Kudos
Post 2 of 2
Re: Fetch Feature License inforamtion with variable FLEXLM_DIAGNOSTICS
03-27-2013 08:20 AM in reply to: mbathala
You can perform a status enquiry from the server status tab of LMTOOLS.  It will show you exactly which feature is checked out to you.  The debug log should also show the OUT feature to your username/computername.
