Installation & Licensing
vesy4477
263 Views, 1 Reply
Fatal Error :
Unhandled Access Violatiom Writing 0xba7c000 Exception at 700e09b2h
please give me a solution for this problem . i can't even open a file .
1 REPLY 1
TravisNave
in reply to: vesy4477
Make sure you have full Admin rights on your machine and there aren't any hard disk or RAM errors listed in your event logs.  Typically these problems can be caused by faulty .NET Framework issues or spyware/virus problems.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
