fatal Error: unhandled access violation reading 0x0000 Exception at 74ae694bh: I have an nvidia gtx670m GPU.
I have tried EVERYTHING in this forum:
Complete system re-install, install CAD error. Uninstall. Uninstall .net, re-install cad, same error. Roll back video driver, error, update again, error. added "nohardware" switch. error.
Install as admin, run as admin, create new account, change permissions, NOTHING WORKS
Seriously, was the last stable verision 2010?
I have been at this for the last 24 hours STRAIGHT!!!
HELP, I am dead in the water with a project due out today.
So the install works OK, no errors?
But when you fire it up, it does not run at all?
Or does it run for a while and then fatal error?
Have you submitted a support request through the subscription center (presuming you are on subscription)?
Hi Steve,
Was the 2014 software previously working on your system? Were there any recent software or hardware changes? Normally when I encounter unhandled exception errors it is a result of the video hardware/driver, The .net framework install. or a corrupt installation of the product. In some cases however it can also be corrupt settings. Have you tried the reset settings to default tool or perhaps trying to login and run the software under a new user account? Also when you say "Complete system re-install" does that mean a format and re-install of your windows OS? If so, what OS version did you re-install?
