Installation & Licensing
New Member
evan.g.mcmahon
Message 1 of 8 (11,474 Views)
fatal error Unhandled Access violation Reading 0xfffffff Exception at e78c0004h
11474 Views, 7 Replies
01-22-2013 06:19 PM
I recently installed AutoCAD 2013 onto my computer which has windows 7 64 bit operating system. After completing installation, I tried to open AutoCAD and immediatly I recieved this error, "Fatal error: Unhandled Access violation Reading 0xffffffff Exception at e78c0004h. I was wondering if anybody knows what that error is signaling and could help me resolve the problem. Thank you!
Make sure you have local admin rights and a certified video driver.  You should also test in another local administrator login to eliminate a profile issue.  If all of those still fail, you might have to reinstall your .NET Framework.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Exception-Errors/td-p/3079002
Good Luck!
TravisNave
Message 2 of 8 (11,404 Views)
Re: fatal error Unhandled Access violation Reading 0xfffffff Exception at e78c00
01-24-2013 08:16 AM in reply to: evan.g.mcmahon
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
New Member
evan.g.mcmahon
Message 3 of 8 (11,376 Views)
01-25-2013 01:08 PM in reply to: TravisNave
The problem was my video card. I have a gtx 660m with optimus and I was getting the error on my dedicated card. I went into my nvidia preferences told it to run autocad using my integrated intel 4000 video card which did the trick. Thank you for all the help, much appreciated!
Thanks!
TravisNave
Message 4 of 8 (11,371 Views)
01-25-2013 01:21 PM in reply to: evan.g.mcmahon
Thanks for following up.  Hopefully it will help the next person!
New Member
al_berk
Message 5 of 8 (10,238 Views)
05-05-2013 03:52 AM in reply to: evan.g.mcmahon
I have the same problem with a new Dell laptop Inspiron 17, running Win 7 Enterprise, having Intel 4000 and ATI Radeon 7600 video cards (why 2?). How do I disable this feature in Radeon? I updated the drivers but didn't find this option.
New Member
hin94730
Message 6 of 8 (4,798 Views)
02-22-2014 02:13 PM in reply to: evan.g.mcmahon
Thank you so much, it solved my fatal error:"unhandled acceess violation reading 0xfffffffexception at e4ee004h". The problem was caused my nvidia video card too.
New Member
bertee18
Message 7 of 8 (4,307 Views)
03-14-2014 02:49 PM in reply to: evan.g.mcmahon
when i start it mine says fatal error Unhandled Access violation Reading 0xfffffff Exception at e6390004h and  an other pop-up saying liscences autodesk.
New Member
SSC1234
Message 8 of 8 (2,496 Views)
06-25-2014 07:16 PM in reply to: evan.g.mcmahon
I am using AutoCAD Map 3D 2013 and have had similar problems with "fatal error Unhandled Access....".
Almost all of my work is in 2D so I don't need to use the 3D features in the program.
After making one simple change in the 3D Performance area, the fatal error no longer occurs.
Tools > Options > tab "System" > 3D Performance; Performance Settings > Panel "Adaptive Degradation and Performance Tuning"
Un-select the "Adaptive degradation" option and press OK to close panel, then select "Apply" under the Options panel. Exit the panel.
This has resolved the problem so far.
