Please help me, i have this error in windows 8 and AutoCAD Architecture 2014. i have tried some fixes i saw here but no response. Can somebody help me???? please
Solved by dembkod. Go to Solution.
When do you get this error? Also, what kind of computer are you running this on?
If it was working 2 days ago, you might consider doing a system restore back to when it was working. Something changed that is causing this to break. Sometimes it is a Windows Update or even a virus.
how can i do a system restore in windows 8? is there any other thing i can try to fix it?
Hello. Errors like this usually revolve around a few areas:
-Corrupt install
-Conflicting Graphics card driver
-Failing Graphics card
I would try acceleration first:
1.) Right-click the program icon on your desktop
2.) Click "Properties"
3.) Access the "Shortcut" tab
4.) In the "Target" field, after ###acad###.exe" type a space and then /NOHARDWARE
5.) Click "OK" and retest
If this does not help, install a new graphics card driver. Go to the manufacturer website for your card (don’t run a Windows Update to search for a driver) and download and test the latest handful of drivers.
Thank you for taking part in our community!
System restore is the safest and quickest thing to try first. And it is fully reversable.
http://windows.microsoft.com/en-us/windows-8/restore-refresh-reset-pc
i DONT KNOW WHY THIS FIX DIDNTE WORKED EARLIER, I USED THIS AND TYPE nohardware IN THE PROPERTIES MENU AND NOW MY autocad WORS FINE. thANK YOU SO MUCH!!!!!!!!!!!!!!!!!!!!
solaressergio,
Hello. You would not normally see a response for a CER report. This is an automated system that feeds into our development area. If there was a known issue with a fix, you may receive an automated email telling you to grab a particular fix, but this is not a way to submit a support request. Subscription users log in and create a case, or users come to the forums.
With that being said, I am glad we could get you rolling. If the /NOHARDWARE switch works for you, it is connected to your graphics. If you update your driver, you may be able to remove this switch and run normally. Some setups may require this, though. Generally, performance may be better without the switch included.
Got to thank you for the fix.
I actually was getting FATAL ERROR: Unhandled Access Violation Writing 0x006c Exception at (changes each time).
This fix worked so thank you very much 1/26/2017
Jan
