Installation & Licensing
*Purdy, Steve
Message 1 of 5 (188 Views)
Fatal Error: Security system is not functioning or is improperly installed
188 Views, 4 Replies
02-28-2001 04:31 AM
We have a network installation of AutoCad Map 3. The machine that hosts the
license manager and a workstation were recently upgraded to Windows 2000.
The license manager and clients were re-installed, and the LM runs fine, and
a second workstation running Windows 95 runs the client without incident.
But the Win2000 workstation won't run the client after installation, giving
the message "Fatal Error: Security system is not functioning or is
improperly installed".
I reviewed the help document on the website and tried several things,
without success:
I can ping the host from the workstation.
The system dates and times are the same.
I tried setting the ACADSERVER to the host name, but it doesn't
"stick"--after I close the command prompt window and reopen it, the
ACADSERVER variable is gone. Don't know what that means. Regardless, it
doesn't correct the problem.
The host is recognizing the workstation. This line appears in the log file:
01-Feb-28 09:37:46: user@workstation [0]: Missed packet: Bad file
descriptor.
Any ideas?
Steve
*martin, jason
Message 2 of 5 (188 Views)
Re: Fatal Error: Security system is not functioning or is improperly installed
02-28-2001 05:47 AM in reply to: *Purdy, Steve
Steve -
Have you updated adesksys.dll? Check out
http://support01.autodesk.com/knowledgebase/html/157553.htm (watch for wrapping in the
link).
You can't set a system variable at the command prompt. It only lasts for that session of
command.exe. To set the variable (if you must) go to start / settings / control panel /
system / Advanced / Environment Variables and set it in the system variables box.
hth
jason martin
frankfurt-short-bruza
"Steve Purdy" wrote in message
news:7842C880017DFC3941076E2D7DDA3D4C@in.WebX.maYIadrTaRb...
> without success:
> descriptor.
> Any ideas?
> Steve
*Purdy, Steve
Message 3 of 5 (188 Views)
Re:
02-28-2001 06:41 AM in reply to: *Purdy, Steve
Thanks, Jason. Reading the installation instructions for adesksys.dll, it
says that if the existing file doesn't have exactly 90112 bytes, not to
proceed. Mine has 85504, so I guess that's out.
I changed the ACADSERVER variable in the manner you suggested, and still no
go.
Thanks anyway.
Steve
"jason martin" wrote in message
news:7030544CE8677F9B388A2AFB8C3DAC46@in.WebX.maYIadrTaRb...
> Steve -
wrapping in the
> link).
that session of
control panel /
variables box.
> hth
> jason martin
the
2000.
and
incident.
giving
> > without success:
it
file:
> > descriptor.
> > Any ideas?
> > Steve
*martin, jason
Message 4 of 5 (188 Views)
Re:
02-28-2001 10:17 AM in reply to: *Purdy, Steve
Do me a favor. Rename the existing adesksys.dll to adesksysdll.old and put
the new one in there. Let me know if it works. If it doesn't you can
always put the old one back. I ran into the same problem. According to the
instructions I shouldn't have replaced the old adesksys.dll, but it wasn't
working so I replaced it anyway and it worked fine.
hth
jason martin
Steve Purdy wrote in message
news:6D8BF5E0360AF1C5DAB1FAD2D4311837@in.WebX.maYIadrTaRb...
no
> go.
> Thanks anyway.
> Steve
> > Steve -
> wrapping in the
> > link).
for
> that session of
> control panel /
> variables box.
> > hth
> > jason martin
hosts
> the
> 2000.
fine,
> and
> incident.
> giving
> > > without success:
> it
> file:
> > > descriptor.
> > > Any ideas?
> > > Steve
*Purdy, Steve
Message 5 of 5 (188 Views)
Re:
03-01-2001 01:49 AM in reply to: *Purdy, Steve
Thank you thank you thank you! It worked!
Steve
news:81A01D5645ABD488080E54E5AEB7B160@in.WebX.maYIadrTaRb...
put
the
> hth
> jason martin
it
> no
> > go.
> > Thanks anyway.
> > Steve
> > > Steve -
> > wrapping in the
> > > link).
> for
> > that session of
> > control panel /
> > variables box.
> > > hth
> > > jason martin
> hosts
> > the
> > 2000.
> fine,
> > and
> > incident.
> > giving
things,
> > > > without success:
Regardless,
> > it
log
> > file:
> > > > descriptor.
> > > > Any ideas?
> > > > Steve
