Installation & Licensing
FATAL ERROR: Security System (hardware lock....
2 REPLIES 2
1895 Views, 2 Replies
Hello All:
I've been searching for a fix to this message. There seem to be a plethora
of issues that might cause this but I haven't found the one that seems to
alleviate it in my instance.
The system is a newly upgraded (cleanly upgraded) XP Pro (was Win2k), Dual
Athlon 1GB RAM, etc. etc. It's plugged in to a standard NT4.0 server TCP/IP
network. There are two other XP Pro systems that are also plugged in and
the Network Install of AutoCAD2000 ran smoothly and both start AutoCAD
without a hitch.
On this upgraded system, the network install ran fine but when I start
AutoCAD2000 I get:
AutoCad Error
Aborting" dialog box stating "FATAL ERROR: security system (hardware lock or
network license) is not functioning or is improperly installed."
When you click okay a memory read error occurs and when click okay again a
memory write error occurs.
No other machines have ever had any troubles getting licenses.
The clock is synchronized. I installed the lates sentinel drivers (even
though it's NOT a hardware locked version). I also checked C-Dilla, just for
kicks along with the Bios parallel port settings - still no luck.
All other network functions (including often finicky internet) are just fine
from this machine.
Any additional direction on fixing this? Is there an 800 number I can call
for support (even if I have to pay!). It seems like someone at AutoDesk
probably has the right answer and it is probably a quick fix.
Thanks in advance.
joel*
[posted to Autodesk.AutoCAD.Network newsgroup 09.08.02]
2 REPLIES 2
check this link:
http://support.autodesk.com/enu/knowledgebase/html/154103.htm
Might do the trick!
/Petri
"j*avery" wrote in message
news:F7BD2B38E52C9E9F6A2E9596193BC9A1@in.WebX.maYIadrTaRb...
> Hello All:
TCP/IP
> without a hitch.
> AutoCAD2000 I get:
> AutoCad Error
or
for
fine
> from this machine.
call
> Thanks in advance.
> joel*
Petri:
That did the trick. I had not found that particular fix when searching.
Thank you very much!
joel*
"Petri Ahava" wrote in message
news:0772B281103BD2537CDAA60088C23DA1@in.WebX.maYIadrTaRb...
> Hi,
> check this link:
> Might do the trick!
> /Petri
Administrator Productivity
