When I'm installing Autodesk Showcase 2012 I get a fatal error when the installer starts installing showcase.
I get a similar error when installing the latest Inventor.
Hope anybody can help.
Here's the logfile:
2011/10/28:23:14:57 Lennard LENNARD-PC === Setup started on LENNARD-PC by Lennard === 2011/10/28:23:14:57 Lennard LENNARD-PC Launch 2011/10/28:23:15:07 Lennard LENNARD-PC PageOpen LaunchDialog 2011/10/28:23:15:18 Lennard LENNARD-PC PageOpen BeginDeploymentDialog 2011/10/28:23:15:46 Lennard LENNARD-PC PageOpen LaunchDialog 2011/10/28:23:16:27 Lennard LENNARD-PC PageOpen LicenseDialog 2011/10/28:23:16:29 Lennard LENNARD-PC PageOpen ProductInfoDialog 2011/10/28:23:16:50 Lennard LENNARD-PC PageOpen ProductSelectionDialog2 2011/10/28:23:17:15 Lennard LENNARD-PC PageOpen FullProgressDialog 2011/10/28:23:17:15 Lennard LENNARD-PC Installing DirectX 9.0 Runtime: D:\Users\Lennard\Downloads\Showcase 2012\3rdParty\DirectX\DXSETUP.exe /SILENT 2011/10/28:23:18:03 Lennard LENNARD-PC Install DirectX 9.0 Runtime Succeeded 2011/10/28:23:18:03 Lennard LENNARD-PC Installing Autodesk® Material Library 2012: TRANSFORMS="C:\Users\Lennard\AppData\Local\Temp\_AI3209.tmp\Content\ADSKMaterials\2012\CM\MaterialLibrary2012-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Users\Lennard\Downloads\Showcase 2012\" INSTALLDIR="C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2011/10/28:23:18:08 Lennard LENNARD-PC Install Autodesk® Material Library 2012 Succeeded 2011/10/28:23:18:08 Lennard LENNARD-PC Installing Autodesk® Material Library 2012 - Base Resolution Image Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Users\Lennard\Downloads\Showcase 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2011/10/28:23:18:24 Lennard LENNARD-PC Install Autodesk® Material Library 2012 - Base Resolution Image Library Succeeded 2011/10/28:23:18:24 Lennard LENNARD-PC Installing Autodesk® Material Library 2012 - Low Resolution Image Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Users\Lennard\Downloads\Showcase 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2011/10/28:23:18:44 Lennard LENNARD-PC Install Autodesk® Material Library 2012 - Low Resolution Image Library Succeeded 2011/10/28:23:18:44 Lennard LENNARD-PC Installing Autodesk® Material Library 2012 - Medium Resolution Image Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Users\Lennard\Downloads\Showcase 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2011/10/28:23:19:12 Lennard LENNARD-PC Install Autodesk® Material Library 2012 - Medium Resolution Image Library Succeeded 2011/10/28:23:19:13 Lennard LENNARD-PC Installing Autodesk® Showcase® 2012: TRANSFORMS="D:\Users\Lennard\Downloads\Showcase 2012\x64\en-us\Showcase\AutodeskShowcase6.0.mst;C:\Users\Lennard\AppData\Local\Temp\_AI3209.tmp\x64\Showcase\AutodeskShowcase6.0-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Users\Lennard\Downloads\Showcase 2012\" INSTALLDIR="C:\Program Files\Autodesk\Showcase 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2011/10/28:23:19:19 Lennard LENNARD-PC Install Autodesk® Showcase® 2012 Failed Installation aborted, Result=1603 2011/10/28:23:19:30 Lennard LENNARD-PC Rollback Autodesk® Material Library 2012 - Medium Resolution Image Library Succeeded 2011/10/28:23:19:38 Lennard LENNARD-PC Rollback Autodesk® Material Library 2012 - Low Resolution Image Library Succeeded 2011/10/28:23:19:48 Lennard LENNARD-PC Rollback Autodesk® Material Library 2012 - Base Resolution Image Library Succeeded 2011/10/28:23:19:58 Lennard LENNARD-PC Rollback Autodesk® Material Library 2012 Succeeded 2011/10/28:23:19:58 Lennard LENNARD-PC Rollback DirectX 9.0 Runtime Failed Failure is ignored, Result=1619
This is a tough error to resolve. Can you re-download the package?
Already tried it, but that didn't seem to fix it either.
I only got them installed a few minutes ago by making a new user account on Windows. And it seems to have fixed the problem.
Thanks for the support anyway.
