hi,
I just downloaded AutoCAD 2014 and this thing pops up while installing
I want to ask if there's a way to fix it
thanks
Start with this Autodesk KB:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15149656&linkID=9240697
Then search here for more information if needed:
For additional information, please consider using Search to assist in your resolution:
Search Autodesk.com
Search Autodesk Discussion Groups
Search Up and Ready Blog
Search Autodesk WikiHelp
I had the "trusted installer" service disabled, i turned it to automatic (enabled) and then just executed the faro ls intaller, and it worked.
Then i disabled the trusted installer again because it annoys my system xD
How did i realize it was the problem?=I tried to delete the folder"V:\Windows\winsxs\InstallTemp\20140629202112613.0"cause it had files like "FARO.LS.manifest", and a message said that i had acces denied, cause i needed permission from trusted installer to make changes to the folder.
Hope this helps 🙂
I have a similar issue with Recap 2019. How do I enable Trusted Installer to automatic? I have searched quite a lot but haven´t found anything so far! Would really appreciate some help!
It's a longish process heres the guide: https://www.windowscentral.com/how-restore-trustedinstaller-owner-system-files-windows-10
