Installation & Licensing
FARO LS 1.1.501.0 error installation
5 REPLIES 5
48059 Views, 5 Replies
hi,
I just downloaded AutoCAD 2014 and this thing pops up while installing
I want to ask if there's a way to fix it
thanks
Tags (1)
5 REPLIES 5
TravisNave
in reply to: TravisNave
hello, is it possible to post a link to the blocked folder and its contents? that would help.
I had the "trusted installer" service disabled, i turned it to automatic (enabled) and then just executed the faro ls intaller, and it worked.
Then i disabled the trusted installer again because it annoys my system xD
How did i realize it was the problem?=I tried to delete the folder"V:\Windows\winsxs\InstallTemp\20140629202112613.0"cause it had files like "FARO.LS.manifest", and a message said that i had acces denied, cause i needed permission from trusted installer to make changes to the folder.
Hope this helps 🙂
castelani456
I have a similar issue with Recap 2019. How do I enable Trusted Installer to automatic? I have searched quite a lot but haven´t found anything so far! Would really appreciate some help!
leowarren34
in reply to: castelani456
It's a longish process heres the guide: https://www.windowscentral.com/how-restore-trustedinstaller-owner-system-files-windows-10
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Administrator Productivity
