I just downloaded and installed revit 2014 but when i try to load a family of any kind or any of the materials library they are not findable.
the only things available are basic wall/slab/roof. nothing else seems to be in the program.
i've downloaded and uninstalled the program a couple of times but the problem continues.
I have revit 2011 still installed.
I have an ADSK Materials folder with a materials library in a RAR file. Is this where they are and if so how do i load them into the program once i've extracted them from the RAR file?
Hugh
Hi h.o_connor,
I've seen this issue happen in the past--specifically when installing from a Network Deployment. Try the following:
Navigate to the Application menu > Options. Once there, go to File Locations > Places and verify the library paths are correct:
Imperial Library - C:\ProgramData\Autodesk\RVT 2014\Libraries\US Imperial
Imperial Detail Library - C:\ProgramData\Autodesk\RVT 2014\Libraries\US Imperial\Detail Items
If the library paths are different then what's shown above, change them to match the above locations.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
