Installation & Licensing
New Member
mattmlee
Message 1 of 4 (2,363 Views)
Failure to install True View 2013
2363 Views, 3 Replies
07-13-2012 10:39 AM
Got through the accepting terms/condtions part, the final installation started and quickly stopped.
I got a "Failed" marker and it said: "Installation complete.  Some products failed to install."
the instillation log file is attached
any help appreciated
Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/3382347
Good Luck!
TravisNave
Message 2 of 4 (2,324 Views)
Re: Failure to install True View 2013
07-16-2012 10:13 AM in reply to: mattmlee
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
New Member
mattmlee
Message 3 of 4 (2,320 Views)
07-16-2012 11:19 AM in reply to: TravisNave
thanks a lot this appears to have worked
TravisNave
Message 4 of 4 (2,316 Views)
07-16-2012 11:24 AM in reply to: mattmlee
Excellent!  Thanks for the update.  :smileyhappy:
