Installation & Licensing
Failure to install True View 2013
3 REPLIES 3
3921 Views, 3 Replies
Got through the accepting terms/condtions part, the final installation started and quickly stopped.
I got a "Failed" marker and it said: "Installation complete.  Some products failed to install."
the instillation log file is attached
any help appreciated
3 REPLIES 3
TravisNave
Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Autodesk Forums:
in reply to: TravisNave
thanks a lot this appears to have worked
TravisNave
Excellent!  Thanks for the update.  Smiley Happy
Autodesk Forums:
Administrator Productivity
