Installation & Licensing
Failure installing Autodesk Design Review 2011
3 REPLIES 3
652 Views, 3 Replies
Trying to install Autodesk Design Review 2011.  The installation keeps failing and the setup log shows: Failed Failure is ignored, Result=1603 Smiley Mad
3 REPLIES 3
hashim.mundol
Installation log in %temp% folder could give you more info.
do you have older version of Design review installed ?
1603 is usually permisssion issue which could be isolated by running install in Diagnostics mode
http://usa.autodesk.com/getdoc/id=TS75218
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
Thank you.  I am trying to install this software on a Windows XP machine with IE 7.  The %temp%\AutoCAD Plant 3D 2011 Setup.log shows:   Install Autodesk Design Review 2011 Failed Failure is ignored, Result=1603.   And from the %temp%\AutoCAD Plant 3D 2011 Install.log -- there is nothing shown for today.  I have tried to install Autodesk Design Review 2011 three times today.   One other thing... This machine did have Autodesk Design Review 2010 on it, however I uninstalled it before trying to install this 2011 version.
hashim.mundol
Did you try diagnostics mode ?
Hashim Mundol
Autodesk, Inc.
Administrator Productivity
