Trying to install Autodesk Design Review 2011. The installation keeps failing and the setup log shows: Failed Failure is ignored, Result=1603
Installation log in %temp% folder could give you more info.
do you have older version of Design review installed ?
1603 is usually permisssion issue which could be isolated by running install in Diagnostics mode
http://usa.autodesk.com/getdoc/id=TS75218
Thank you. I am trying to install this software on a Windows XP machine with IE 7. The %temp%\AutoCAD Plant 3D 2011 Setup.log shows: Install Autodesk Design Review 2011 Failed Failure is ignored, Result=1603. And from the %temp%\AutoCAD Plant 3D 2011 Install.log -- there is nothing shown for today. I have tried to install Autodesk Design Review 2011 three times today. One other thing... This machine did have Autodesk Design Review 2010 on it, however I uninstalled it before trying to install this 2011 version.
Did you try diagnostics mode ?
