I'm in desperate need of installing AutoCad back onto my Mac (using Snow Leopard). I used to have AutoCad 2011, but started working funny and incorrectly so I decided to change to the 2013 Student version.
The process goes fine but when I actually have to start the program the first time (to activate it), I get the loading image and then nothing happens (see attached image), it disappears and the program doesn't start.
Could someone please help me? I need to get it started as soon as possible, I have lots of homework to do! Thank you
Welcome to the community Anastasia!
Can you confirm that you're running the most current version / AutoCAD for Mac SP1?
What happens if you try launching the software from a terminal window?
Using Terminal:
Open a Terminal window (the Terminal app is typically found in the /Applications/Utilities folder).
Type /Applications/Autodesk/AutoCAD\ 2013/AutoCAD.app/Contents/MacOS/AutoCAD -nologo and press return.
Quit the Terminal application.
Please accept as a solution if this fully resolves the issue, or reply with additional details if the problem persists.
Thank you.
When I type in what you asked me in Terminal, I get this : "No such file or directory".
I downloaded the latest Service Pack (the 3 I think) and I think I've tried the 1 and it still doesn't work...
Just letting you know, I solved the problem another way : I did a factory reset of my macbook pro and redownloaded autocad 2013 and now it works fine. I think that when I uninstalled the 2011 version, for some reason it wasn't correctly executed even if I uninstalled it properly (not by simply putting it in the trash). I guess that's what made my autocad crash.
Thank you for trying to help!
You're most very welcome Anastasia and thank you for sharing your solution with the community!
