Installation & Licensing
failure installing architecture 2014
3 REPLIES 3
gveaux
325 Views, 3 Replies
I am having problems installing architecture 2014. it fails to install everytime I try to install.
I had the same issues with 2013 architecture, I have just been working off of standard autocad for the past year.
any suggestions would be greatly appreciated.
3 REPLIES 3
gveaux
in reply to: gveaux
im getting the failure codes 1603 and 1619
TravisNave
in reply to: gveaux
It's failing on Sketchbook.  Uncheck it during the installation.  You probably don't need it.  You should be good on the rest.  If others fail, repost.
Install Autodesk® SketchBook® Designer 2014 Failed Installation aborted, Result=1603
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
gveaux
in reply to: TravisNave
I figured out my issue.
autodesk support had me re-path my temp files and that fixed my issues
http://upandready.typepad.com/up_and_ready/2012/10/autocad-installation-error-entrypoint-streamoutfn...
Administrator Productivity
