Installation & Licensing
Active Member
0 Kudos
Post 1 of 4
Failing 2012 Map 3D Instll
605 Views, 3 Replies
04-12-2012 08:26 AM
Had to roll back .net at first, then the install progressed a little further. Not sure what I need to do if anyone can help.
2012/4/12:08:40:38 jeffrey.bowlin C1F17L1 === Setup started on C1F17L1 by jeffrey.bowlin ===
2012/4/12:08:40:38 jeffrey.bowlin C1F17L1 Launch
2012/4/12:08:48:19 jeffrey.bowlin C1F17L1 === Setup ended ===
2012/4/12:08:41:38 jeffrey.bowlin C1F17L1 === Setup started on C1F17L1 by jeffrey.bowlin ===
2012/4/12:08:41:38 jeffrey.bowlin C1F17L1 Launch
2012/4/12:08:46:23 jeffrey.bowlin C1F17L1 Installing .NET Framework Runtime 4.0: \\swiknxbin10\CAE Deployments\AutoDesk\2012_Map3D_64bit\AdminImage\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2012/4/12:08:51:35 jeffrey.bowlin C1F17L1 Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
2012/4/12:08:51:59 jeffrey.bowlin C1F17L1 === Setup ended ===
2012/4/12:09:37:21 jeffrey.bowlin C1F17L1 === Setup started on C1F17L1 by jeffrey.bowlin ===
2012/4/12:09:37:21 jeffrey.bowlin C1F17L1 Launch
2012/4/12:09:42:59 jeffrey.bowlin C1F17L1 === Setup ended ===
2012/4/12:09:38:04 jeffrey.bowlin C1F17L1 === Setup started on C1F17L1 by jeffrey.bowlin ===
2012/4/12:09:38:04 jeffrey.bowlin C1F17L1 Launch
2012/4/12:09:41:50 jeffrey.bowlin C1F17L1 Installing DirectX Runtime: \\swiknxbin10\CAE Deployments\AutoDesk\2012_Map3D_64bit\AdminImage\3rdParty\DirectX\DXSETUP.exe /silent
2012/4/12:09:47:05 jeffrey.bowlin C1F17L1 Install DirectX Runtime Succeeded
2012/4/12:09:47:05 jeffrey.bowlin C1F17L1 Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\swiknxbin10\CAE Deployments\AutoDesk\2012_Map3D_64bit\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/4/12:10:03:39 jeffrey.bowlin C1F17L1 Install FaroSDK Failed Failure is ignored, Result=1603
2012/4/12:10:03:39 jeffrey.bowlin C1F17L1 Installing Autodesk Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\swiknxbin10\CAE Deployments\AutoDesk\2012_Map3D_64bit\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/4/12:10:10:01 jeffrey.bowlin C1F17L1 Install Autodesk Material Library 2012 Succeeded
2012/4/12:10:10:01 jeffrey.bowlin C1F17L1 Installing Autodesk Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\swiknxbin10\CAE Deployments\AutoDesk\2012_Map3D_64bit\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/4/12:10:15:02 jeffrey.bowlin C1F17L1 Install Autodesk Material Library 2012 - Low Resolution Succeeded
2012/4/12:10:15:02 jeffrey.bowlin C1F17L1 Installing Microsoft Visual C++ 2005 Redistributable (x86): \\swiknxbin10\CAE Deployments\AutoDesk\2012_Map3D_64bit\AdminImage\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\JEFFRE~1.BOW\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/4/12:10:30:31 jeffrey.bowlin C1F17L1 Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2012/4/12:10:30:45 jeffrey.bowlin C1F17L1 Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2012/4/12:10:31:04 jeffrey.bowlin C1F17L1 Rollback Autodesk Material Library 2012 Succeeded
2012/4/12:10:31:04 jeffrey.bowlin C1F17L1 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/4/12:10:31:22 jeffrey.bowlin C1F17L1 === Setup ended ===
902 Kudos
Post 2 of 4
Re: Failing 2012 Map 3D Instll
04-12-2012 05:22 PM in reply to: JeffBowlin
Install ​Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Active Member
0 Kudos
Post 3 of 4
04-18-2012 06:22 AM in reply to: JeffBowlin
Product installed after machine was reimaged. After installation, app opened, all menus present.
End user however has no menus, and has some isse saving profile....
ugh
902 Kudos
Post 4 of 4
04-18-2012 07:56 AM in reply to: JeffBowlin
Make sure the end user has local administrator rights and that the My Documents folder is not being redirected.
