I recently installed AutocadMap 12 without any problems...
I started running into problems with the windows installer popping up everytime i would open another program.
I tried to uninstall Autocadmap 12 but i keep getting the "Failed to get allied products" error message, it won't repair the installation and now fails when i try to re-install the program...
So now i can't do anything....
I'm running windows XP
any help would be greatly appreciated as there is nothing on the web that can help...
Consider using the Microsoft Installer Clean Up Utility (Recommended only for Windows XP.) For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
That will help you remove the program. You can then reinstall it cleanly. If you still get installation errors, post the log files from your %TEMP% folder. Good Luck!
