Installation & Licensing
368 Views, 3 Replies
Failed to install
Hi there
I'm trying to download Revit Architecture 2012 student version (and I desperately need to start using it ASAP!!)
I get an error message saying that the software failed to install and under the design review installation log file, it suggests that it can't install Microsoft Visual C++ 2010 Redistributable (x86) but I already have it loaded on my machine. Do I need to uninstall it before loading Revit 2012?
As for Revit Architecture and the Materials Library - there's no indication why it wouldn't load. Help!!
I installed Revit 2013 no problem at all but had to uninstall it because at school they're using 2012.  I'm pretty sure I've uninstalled it properly...
3 REPLIES 3
DannyHubbard
Yes you first need to uninstall the Visual Studio 2010 redistributables then try installing Revit 2012 again.
http://upandready.typepad.com/up_and_ready/2012/05/autodesk-design-review-2012-microsoft-visual-c-20...
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
TravisNave
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
This worked!  Thank you
Administrator Productivity
