Installation & Licensing
FAILED TO INSTALL REVIT ARCHITECTURE
2 REPLIES 2
626 Views, 2 Replies
It stated that some installations are corrupt and asked me to download a fresh copy and retry the installations.
"CRC failed in 3rdParty\DirectX\JUN2008_XACT_x86.cabUnexpected end of archive"
After downloading again, the same problem arise..
2 REPLIES 2
TravisNave
Use an alternate browser method and make sure your realtime virus scanner is disabled.  Might even try it from another computer altogether.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
 "CRC failed in 3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe The file "???" header is corrupt"
i have tried to install again but found the same problem what to do?
Administrator Productivity
