I've tried downloading several different times and even tried searching through forums looking for answers. I manually removed all of the Microsoft Visual C++ service packs and tried downloading it again. I really need this on my personal computer for class...
Here is apart of the log..
2014/8/23:13:51:03 krisw_000 KNOWLEDGE Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2014/8/23:13:51:54 krisw_000 KNOWLEDGE Rollback Autodesk Material Library 2014 Succeeded
2014/8/23:13:51:57 krisw_000 KNOWLEDGE Rollback Autodesk Workflows 2014 Succeeded
2014/8/23:13:52:13 krisw_000 KNOWLEDGE Rollback Autodesk® Revit® 2014 Language Pack Succeeded
2014/8/23:14:00:11 krisw_000 KNOWLEDGE Rollback Autodesk® Revit® 2014 Succeeded
2014/8/23:14:00:11 krisw_000 KNOWLEDGE Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/8/23:14:00:12 krisw_000 KNOWLEDGE Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1619
2014/8/23:14:00:12 krisw_000 KNOWLEDGE Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619
2014/8/23:14:00:12 krisw_000 KNOWLEDGE Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2014/8/23:14:00:12 krisw_000 KNOWLEDGE Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2014/8/23:14:00:12 krisw_000 KNOWLEDGE Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2014/8/23:14:00:12 krisw_000 KNOWLEDGE Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
Post the whole log. That portion is not helpful. The failure will come above the rollbacks.
I tried installing it via virtual assistant, and it worked!!!! Problem solved.
