Installation & Licensing
Failed to get allied products
1 REPLY 1
rado7rado
2175 Views, 1 Reply
Hello
I hawe problem to reinstall autocad.I hawe problem with crashing windows explorer so i uninstalled program after program to find out wich program is responsible for this problem.Now i will to instal again autocad 2014 and now there is no way to instal.There is always an error.Please i need help for install autocad again.I hawe windows 8.1.
1 REPLY 1
pendean
in reply to: rado7rado
Win 8.1 is not fully supported yet.
Did you actually fix your initial problem?
Did your problem show up when you updated to Win8.1? If not, why didn't you use Windows System Restore to fix it instead of the ill-advised method you performed? Was that a recommendation from somewhere?
It's best to remove all Autidesk products, all Windows Registry entries for all things Autodesk and AutoCAD, run a windows registry cleaner, restart Windows then try again.
Administrator Productivity
