Each time I attempt to install C3D 2012, after the insatll nearly finishing I get an error window stating "Failed to find node" and long message along with it. I'm running WIN7, 64 bit, and I've never had any trouble installing any previous versions.
Any ideas? I've included the error window.
Solved by david.lau. Go to Solution.
Thanks David! That took care of it. I guess I didn't get all the beta goodies removed before trying to install the real thing.
Hi I am having the same problem
I am trying to install ACA 2012 but I already have installed ACA2013, the only content service I can see is for 2013,
if i delete it what will happen to ACA 2013?
can you please help?
Thanks in advance for any help you may be able to give
Having the same issue reinstalling 2012 C3D with a copy of 2014 already installed. Does delting the content service mess up my 2014 install?
It is always recommended to install your products oldest to newest because there are some shared components, like the content service, that will be upgraded. When the older products install is trying to install it's own content service it will run into errors because a newer version is already there if you have installed a newer version first. The best practice is to install everything oldest to newest.
