Installation & Licensing
Failed to aquire a license from Server
2 REPLIES 2
302 Views, 2 Replies
Installation of workstation was as expected - Serial Number, Product key and Server name all accepted during installation
When the workstation requests a key for Autodesk Inventor LT Suite, the request arrives on Port 27000 but immediately after that the workstation sends a disconnect on the same port.
Unlike other workstations making the same request, there is no scan requests of ports 27001 through 27009.
There is not set up of communications on port 2080.
We have confirmed there are no firewalls in the way from the workstation to the server and the network routes are working fine.
Any ideas on what may be causing this issue would be appreciated
2 REPLIES 2
DarrenP
need more info
what error message are you getting when you launch the autodesk product?
DarrenP
TravisNave
Darren is right.  Give us some debug logs and server status enquiries.  And also any error that pops at the client.
Also, have you PINGed the server and verified IPv4?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
