3ds Max Design 2012 Setup.log
2013/9/10:18:50:47 version36 V36 === Setup started on V36 by version36 ===
2013/9/10:18:50:47 version36 V36 Launch
2013/9/10:18:51:08 version36 V36 System Component Update MSI Runtime (3010)
2013/9/10:18:51:25 version36 V36 === Setup ended ===
2013/9/10:18:51:08 version36 V36 === Setup started on V36 by version36 ===
2013/9/10:18:51:08 version36 V36 Launch
2013/9/10:18:51:26 version36 V36 PageOpen LaunchDialog
2013/9/10:18:52:55 version36 V36 PageOpen LicenseDialog
2013/9/10:18:53:05 version36 V36 PageOpen ProductInfoDialog
2013/9/10:18:57:35 version36 V36 PageOpen ProductSelectionDialog2
2013/9/10:18:58:01 version36 V36 PageOpen FullProgressDialog
2013/9/10:18:58:01 version36 V36 Installing Microsoft Visual C++ 2005 Redistributable (x86): D:\3ds\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:D:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v D:\DOCUME~1\VERSIO~1\LOCALS~1\Temp\vcredist_x86_2005.log"" "
2013/9/10:18:58:09 version36 V36 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2013/9/10:18:58:09 version36 V36 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): D:\3ds\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/9/10:18:58:13 version36 V36 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/9/10:18:58:13 version36 V36 Installing .NET Framework Runtime 3.5 SP1: D:\3ds\3rdParty\NET\35SP1\wcu\dotNetFramework\dotNetFx35setup.exe /q /norestart
2013/9/10:19:07:16 version36 V36 Install .NET Framework Runtime 3.5 SP1 Succeeded
2013/9/10:19:07:16 version36 V36 Installing DirectX® Runtime: D:\3ds\3rdParty\DirectX\DXSETUP.exe /silent
2013/9/10:19:07:17 version36 V36 Install DirectX® Runtime Succeeded
2013/9/10:19:07:17 version36 V36 Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\3ds\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/9/10:19:08:11 version36 V36 Install Autodesk Material Library 2012 Succeeded
2013/9/10:19:08:11 version36 V36 Installing Autodesk Material Library 2012 - Base Image Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\3ds\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/9/10:19:09:39 version36 V36 Install Autodesk Material Library 2012 - Base Image Library Succeeded
2013/9/10:19:09:39 version36 V36 Installing Autodesk Material Library 2012 - Medium Resolution Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\3ds\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/9/10:19:14:26 version36 V36 Install Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2013/9/10:19:14:26 version36 V36 Installing Autodesk® Backburner 2012: D:\3ds\x86\Components\backburner\BackburnerCIF.exe
2013/9/10:19:14:26 version36 V36 Install Autodesk® Backburner 2012 Failed Installation aborted, Result=193
2013/9/10:19:16:30 version36 V36 Rollback Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2013/9/10:19:18:34 version36 V36 Rollback Autodesk Material Library 2012 - Base Image Library Succeeded
2013/9/10:19:21:42 version36 V36 Rollback Autodesk Material Library 2012 Succeeded
2013/9/10:19:21:42 version36 V36 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/9/10:19:21:42 version36 V36 Rollback .NET Framework Runtime 3.5 SP1 Failed Failure is ignored, Result=1619
2013/9/10:19:21:43 version36 V36 Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2013/9/10:19:21:43 version36 V36 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2013/9/10:19:21:45 version36 V36 PageOpen InstallCompleteDialog
2013/9/10:19:23:32 version36 V36 === Setup ended ===
2013/9/10:19:56:33 version36 V36 === Setup started on V36 by version36 ===
2013/9/10:19:56:33 version36 V36 Launch
2013/9/10:19:56:58 version36 V36 === Setup ended ===
2013/9/10:19:56:34 version36 V36 === Setup started on V36 by version36 ===
2013/9/10:19:56:34 version36 V36 Launch
2013/9/10:19:56:59 version36 V36 PageOpen LaunchDialog
2013/9/10:19:57:19 version36 V36 PageOpen LicenseDialog
2013/9/10:19:57:34 version36 V36 PageOpen ProductInfoDialog
2013/9/10:20:05:15 version36 V36 PageOpen ProductSelectionDialog2
2013/9/10:20:05:32 version36 V36 PageOpen FullProgressDialog
2013/9/10:20:05:32 version36 V36 Installing DirectX® Runtime: d:\Autodesk\Autodesk_3ds_Max_Design_2012_English_Win_32-64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/9/10:20:05:33 version36 V36 Install DirectX® Runtime Succeeded
2013/9/10:20:05:33 version36 V36 Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="d:\Autodesk\Autodesk_3ds_Max_Design_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/9/10:20:06:11 version36 V36 Install Autodesk Material Library 2012 Succeeded
2013/9/10:20:06:11 version36 V36 Installing Autodesk Material Library 2012 - Base Image Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="d:\Autodesk\Autodesk_3ds_Max_Design_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/9/10:20:06:50 version36 V36 Install Autodesk Material Library 2012 - Base Image Library Succeeded
2013/9/10:20:06:50 version36 V36 Installing Autodesk Material Library 2012 - Medium Resolution Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="d:\Autodesk\Autodesk_3ds_Max_Design_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/9/10:20:08:12 version36 V36 Install Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2013/9/10:20:08:12 version36 V36 Installing Autodesk® Backburner 2012: d:\Autodesk\Autodesk_3ds_Max_Design_2012_English_Win_32-64bit\x86\Components\backburner\BackburnerCIF.exe
2013/9/10:20:08:12 version36 V36 Install Autodesk® Backburner 2012 Failed Installation aborted, Result=193
2013/9/10:20:08:34 version36 V36 Rollback Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2013/9/10:20:08:58 version36 V36 Rollback Autodesk Material Library 2012 - Base Image Library Succeeded
2013/9/10:20:09:41 version36 V36 Rollback Autodesk Material Library 2012 Succeeded
2013/9/10:20:09:41 version36 V36 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/9/10:20:09:44 version36 V36 PageOpen InstallCompleteDialog
2013/9/10:20:17:11 version36 V36 === Setup ended ===
2013/9/10:20:17:17 version36 V36 === Setup started on V36 by version36 ===
2013/9/10:20:17:17 version36 V36 Launch
2013/9/10:20:17:22 version36 V36 === Setup ended ===
2013/9/10:20:17:19 version36 V36 === Setup started on V36 by version36 ===
2013/9/10:20:17:19 version36 V36 Launch
2013/9/10:20:17:22 version36 V36 PageOpen LaunchDialog
2013/9/10:20:18:19 version36 V36 PageOpen BeginDeploymentDialog
2013/9/10:20:18:48 version36 V36 PageOpen LaunchDialog
2013/9/10:20:18:50 version36 V36 PageOpen LicenseDialog
2013/9/10:20:18:50 version36 V36 PageOpen ProductSelectionDialog2
2013/9/10:20:19:15 version36 V36 PageOpen LicenseDialog
2013/9/10:20:19:15 version36 V36 PageOpen LaunchDialog
2013/9/10:20:19:48 version36 V36 PageOpen LicenseDialog
2013/9/10:20:27:06 version36 V36 PageOpen ProductInfoDialog
2013/9/10:20:30:10 version36 V36 PageOpen ProductSelectionDialog2
2013/9/10:20:30:21 version36 V36 PageOpen FullProgressDialog
2013/9/10:20:30:21 version36 V36 Installing DirectX® Runtime: D:\Autodesk\Autodesk_3ds_Max_Design_2012_English_Win_32-64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/9/10:20:30:21 version36 V36 Install DirectX® Runtime Succeeded
2013/9/10:20:30:21 version36 V36 Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_3ds_Max_Design_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/9/10:20:30:55 version36 V36 Install Autodesk Material Library 2012 Succeeded
2013/9/10:20:30:55 version36 V36 Installing Autodesk Material Library 2012 - Base Image Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_3ds_Max_Design_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/9/10:20:31:31 version36 V36 Install Autodesk Material Library 2012 - Base Image Library Succeeded
2013/9/10:20:31:31 version36 V36 Installing Autodesk Material Library 2012 - Medium Resolution Library: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_3ds_Max_Design_2012_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/9/10:20:32:46 version36 V36 Install Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2013/9/10:20:32:47 version36 V36 Installing Autodesk® Backburner 2012: D:\Autodesk\Autodesk_3ds_Max_Design_2012_English_Win_32-64bit\x86\Components\backburner\BackburnerCIF.exe
2013/9/10:20:32:47 version36 V36 Install Autodesk® Backburner 2012 Failed Installation aborted, Result=193
2013/9/10:20:33:08 version36 V36 Rollback Autodesk Material Library 2012 - Medium Resolution Library Succeeded
2013/9/10:20:33:29 version36 V36 Rollback Autodesk Material Library 2012 - Base Image Library Succeeded
2013/9/10:20:34:12 version36 V36 Rollback Autodesk Material Library 2012 Succeeded
2013/9/10:20:34:12 version36 V36 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/9/10:20:34:14 version36 V36 PageOpen InstallCompleteDialog
2013/9/10:20:34:39 version36 V36 === Setup ended ===
2013/9/10:21:16:22 version36 V36 === Setup started on V36 by version36 ===
2013/9/10:21:16:22 version36 V36 Launch
2013/9/10:21:16:27 version36 V36 === Setup ended ===
Help Me...!
Msn/Facebook : mhmt-36@hotmail.com
FB : www.facebook.com/mhmt3606
Hello. Thank you for the log. Search on the work “Failed” and look for all NON-Autodesk programs, specifically C++ and NET. Here I see errors to both NET and C++. Uninstall them and try to install again. They are common blocks if they are out of sync.
Thank you for taking part in our community!
