Installation & Licensing
Failed installing Inventor 2014 trail version. Error inventor.msi
4 REPLIES 4
Rosurfing
2533 Views, 4 Replies
Downloaded Free Trail from Autodesk.com
While installing an error message appears, ref attachment:
The system cannot open the device or file specified.
D:\Temp_AID4CC.tmp\x86\inventor\inventor.msi
The file "inventor.msi" is in the specified folder but for some reason the installer cannot open this file.
I'm using Windows 7 on a 64 bit system.
Thanks in advance!
4 REPLIES 4
TravisNave
in reply to: Rosurfing
Welcome to the peer forums.
This is due to your antivirus program.
See this KB article:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889889&linkID=9240697
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Rosurfing
in reply to: TravisNave
Thanks for your reply, Travis.
You may be right about the antivirus program. I have Trend installed. It's a company PC and they don't allow to disable or uninstall the virus scanner. It's PW protected so not accessible for me.
The second option, Setting Environment Variables to a different folder doesn's solve the problem either. I get the same error.
Any ideas???
TravisNave
Unless you can disabled it in the services.msc, you will likely have to get IT to disable it for you during the install.
Autodesk Forums:
Rosurfing
Ok wil ask IT for help. Thanks
Administrator Productivity
