Receive message "An error occurred while installing this product. For more information view the installation log file." after failed attempt to install AutoCAD Mechanical 2013.
Log file text:
2013/3/12:06:13:42 jon.wood PRN-972SSN1 === Setup started on PRN-972SSN1 by jon.wood === 2013/3/12:06:13:42 jon.wood PRN-972SSN1 Launch 2013/3/12:06:14:29 jon.wood PRN-972SSN1 === Setup ended ===
2013/3/12:06:14:05 jon.wood PRN-972SSN1 === Setup started on PRN-972SSN1 by jon.wood === 2013/3/12:06:14:05 jon.wood PRN-972SSN1 Launch 2013/3/12:06:14:27 jon.wood PRN-972SSN1 Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message: 2013/3/12:06:14:27 jon.wood PRN-972SSN1 Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message: 2013/3/12:06:14:28 jon.wood PRN-972SSN1 PageOpen LaunchDialog 2013/3/12:06:14:33 jon.wood PRN-972SSN1 PageOpen LicenseDialog 2013/3/12:06:14:35 jon.wood PRN-972SSN1 PageOpen ProductInfoDialog 2013/3/12:06:15:23 jon.wood PRN-972SSN1 PageOpen ProductSelectionDialog2 2013/3/12:06:16:30 jon.wood PRN-972SSN1 PageOpen FullProgressDialog 2013/3/12:06:16:30 jon.wood PRN-972SSN1 Installing DirectX® Runtime: H:\3rdParty\DirectX\DXSETUP.exe /silent 2013/3/12:06:19:34 jon.wood PRN-972SSN1 Install DirectX® Runtime Succeeded 2013/3/12:06:19:36 jon.wood PRN-972SSN1 Installing AutoCAD® Mechanical 2013: TRANSFORMS="H:\x64\en-us\acadm\acad.mst;C:\Users\JON~1.WOO\AppData\Local\Temp\_AIE040.tmp\x64\acadm\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/12:06:27:17 jon.wood PRN-972SSN1 Install AutoCAD® Mechanical 2013 Failed Installation aborted, Result=1603 2013/3/12:06:27:18 jon.wood PRN-972SSN1 PageOpen InstallCompleteDialog 2013/3/12:06:31:02 jon.wood PRN-972SSN1 === Setup ended ===
2013/3/12:06:49:17 jon.wood PRN-972SSN1 === Setup started on PRN-972SSN1 by jon.wood === 2013/3/12:06:49:17 jon.wood PRN-972SSN1 Launch 2013/3/12:06:50:03 jon.wood PRN-972SSN1 === Setup ended ===
2013/3/12:06:49:41 jon.wood PRN-972SSN1 === Setup started on PRN-972SSN1 by jon.wood === 2013/3/12:06:49:41 jon.wood PRN-972SSN1 Launch 2013/3/12:06:50:02 jon.wood PRN-972SSN1 Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message: 2013/3/12:06:50:02 jon.wood PRN-972SSN1 Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message: 2013/3/12:06:50:03 jon.wood PRN-972SSN1 PageOpen LaunchDialog 2013/3/12:06:50:06 jon.wood PRN-972SSN1 PageOpen LicenseDialog 2013/3/12:06:50:10 jon.wood PRN-972SSN1 PageOpen ProductInfoDialog 2013/3/12:06:50:46 jon.wood PRN-972SSN1 PageOpen ProductSelectionDialog2 2013/3/12:06:51:39 jon.wood PRN-972SSN1 PageOpen FullProgressDialog 2013/3/12:06:51:39 jon.wood PRN-972SSN1 Installing DirectX® Runtime: H:\3rdParty\DirectX\DXSETUP.exe /silent 2013/3/12:06:54:12 jon.wood PRN-972SSN1 Install DirectX® Runtime Succeeded 2013/3/12:06:54:14 jon.wood PRN-972SSN1 Installing AutoCAD® Mechanical 2013: TRANSFORMS="H:\x64\en-us\acadm\acad.mst;C:\Users\JON~1.WOO\AppData\Local\Temp\_AIAE77.tmp\x64\acadm\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/12:07:00:20 jon.wood PRN-972SSN1 Install AutoCAD® Mechanical 2013 Failed Installation aborted, Result=1603 2013/3/12:07:00:21 jon.wood PRN-972SSN1 PageOpen InstallCompleteDialog 2013/3/12:07:00:49 jon.wood PRN-972SSN1 === Setup ended ===
2013/3/12:07:30:33 jon.wood PRN-972SSN1 === Setup started on PRN-972SSN1 by jon.wood === 2013/3/12:07:30:33 jon.wood PRN-972SSN1 Launch 2013/3/12:07:31:16 jon.wood PRN-972SSN1 === Setup ended ===
2013/3/12:07:30:56 jon.wood PRN-972SSN1 === Setup started on PRN-972SSN1 by jon.wood === 2013/3/12:07:30:56 jon.wood PRN-972SSN1 Launch 2013/3/12:07:30:56 jon.wood PRN-972SSN1 [Error: 1052] The requested control is not valid for this service. 2013/3/12:07:31:14 jon.wood PRN-972SSN1 Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message: 2013/3/12:07:31:14 jon.wood PRN-972SSN1 Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message: 2013/3/12:07:31:16 jon.wood PRN-972SSN1 PageOpen LaunchDialog 2013/3/12:07:31:19 jon.wood PRN-972SSN1 PageOpen LicenseDialog 2013/3/12:07:31:21 jon.wood PRN-972SSN1 PageOpen ProductInfoDialog 2013/3/12:07:32:54 jon.wood PRN-972SSN1 PageOpen ProductSelectionDialog2 2013/3/12:07:33:23 jon.wood PRN-972SSN1 PageOpen FullProgressDialog 2013/3/12:07:33:24 jon.wood PRN-972SSN1 Installing DirectX® Runtime: H:\3rdParty\DirectX\DXSETUP.exe /silent 2013/3/12:07:35:54 jon.wood PRN-972SSN1 Install DirectX® Runtime Succeeded 2013/3/12:07:35:56 jon.wood PRN-972SSN1 Installing AutoCAD® Mechanical 2013: TRANSFORMS="H:\x64\en-us\acadm\acad.mst;C:\Users\JON~1.WOO\AppData\Local\Temp\_AI94BF.tmp\x64\acadm\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/12:07:42:22 jon.wood PRN-972SSN1 Install AutoCAD® Mechanical 2013 Failed Installation aborted, Result=1603 2013/3/12:07:42:23 jon.wood PRN-972SSN1 PageOpen InstallCompleteDialog 2013/3/12:07:45:15 jon.wood PRN-972SSN1 === Setup ended ===
2013/3/12:07:52:43 jon.wood PRN-972SSN1 === Setup started on PRN-972SSN1 by jon.wood === 2013/3/12:07:52:43 jon.wood PRN-972SSN1 Launch 2013/3/12:07:53:26 jon.wood PRN-972SSN1 === Setup ended ===
2013/3/12:07:53:06 jon.wood PRN-972SSN1 === Setup started on PRN-972SSN1 by jon.wood === 2013/3/12:07:53:06 jon.wood PRN-972SSN1 Launch 2013/3/12:07:53:24 jon.wood PRN-972SSN1 Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message: 2013/3/12:07:53:24 jon.wood PRN-972SSN1 Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message: 2013/3/12:07:53:25 jon.wood PRN-972SSN1 PageOpen LaunchDialog 2013/3/12:07:53:29 jon.wood PRN-972SSN1 PageOpen LicenseDialog 2013/3/12:07:53:32 jon.wood PRN-972SSN1 PageOpen ProductInfoDialog 2013/3/12:07:54:13 jon.wood PRN-972SSN1 PageOpen ProductSelectionDialog2 2013/3/12:07:54:38 jon.wood PRN-972SSN1 PageOpen FullProgressDialog 2013/3/12:07:54:38 jon.wood PRN-972SSN1 Installing DirectX® Runtime: H:\3rdParty\DirectX\DXSETUP.exe /silent 2013/3/12:07:57:10 jon.wood PRN-972SSN1 Install DirectX® Runtime Succeeded 2013/3/12:07:57:12 jon.wood PRN-972SSN1 Installing AutoCAD® Mechanical 2013: TRANSFORMS="H:\x64\en-us\acadm\acad.mst;C:\Users\JON~1.WOO\AppData\Local\Temp\_AI3310.tmp\x64\acadm\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/12:08:03:24 jon.wood PRN-972SSN1 Install AutoCAD® Mechanical 2013 Failed Installation aborted, Result=1603 2013/3/12:08:03:25 jon.wood PRN-972SSN1 PageOpen InstallCompleteDialog 2013/3/12:08:04:36 jon.wood PRN-972SSN1 === Setup ended ===
2013/3/12:08:53:11 jon.wood PRN-972SSN1 === Setup started on PRN-972SSN1 by jon.wood === 2013/3/12:08:53:11 jon.wood PRN-972SSN1 Launch 2013/3/12:08:53:54 jon.wood PRN-972SSN1 === Setup ended ===
2013/3/12:08:53:33 jon.wood PRN-972SSN1 === Setup started on PRN-972SSN1 by jon.wood === 2013/3/12:08:53:33 jon.wood PRN-972SSN1 Launch 2013/3/12:08:53:53 jon.wood PRN-972SSN1 Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message: 2013/3/12:08:53:53 jon.wood PRN-972SSN1 Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message: 2013/3/12:08:53:54 jon.wood PRN-972SSN1 PageOpen LaunchDialog 2013/3/12:08:54:02 jon.wood PRN-972SSN1 PageOpen LicenseDialog 2013/3/12:08:54:06 jon.wood PRN-972SSN1 PageOpen ProductInfoDialog 2013/3/12:08:54:30 jon.wood PRN-972SSN1 PageOpen ProductSelectionDialog2 2013/3/12:08:55:56 jon.wood PRN-972SSN1 PageOpen FullProgressDialog 2013/3/12:08:55:56 jon.wood PRN-972SSN1 Installing DirectX® Runtime: H:\3rdParty\DirectX\DXSETUP.exe /silent 2013/3/12:08:58:22 jon.wood PRN-972SSN1 Install DirectX® Runtime Succeeded 2013/3/12:08:58:24 jon.wood PRN-972SSN1 Installing AutoCAD® Mechanical 2013: TRANSFORMS="H:\x64\en-us\acadm\acad.mst;C:\Users\JON~1.WOO\AppData\Local\Temp\_AI89E8.tmp\x64\acadm\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/3/12:09:05:07 jon.wood PRN-972SSN1 Install AutoCAD® Mechanical 2013 Failed Installation aborted, Result=1603
Make sure you are installing with admin rights, UAC off, and anti-virus disabled. And make sure that there is not already another flavor of AutoCAD 2013 already installed. Lastly, during your install, do not choose to install the service packs with the installation. Install them after.
