Installation & Licensing
Failed Installation aborted, Result=193
5 REPLIES 5
toxxxteth
1459 Views, 5 Replies
i am facing problem while installing AutoCAD 2013 on my win 8 tablet..i am getting error 193.. i ve checked internet about this error and try some modifications but couldnt solve it.. i deleted all windows visual c++ 2005 and 2008 versions and also 2010 (x86)... kept only 2010 (x64)... please check my log file...looking forward your help, thanks in advance
2013/10/27:21:33:56 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:33:56 ahmet naim AHMETNAIM Launch
2013/10/27:21:33:59 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:33:57 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:33:57 ahmet naim AHMETNAIM Launch
2013/10/27:21:33:59 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:21:34:04 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:21:34:06 ahmet naim AHMETNAIM PageOpen ProductInfoDialog
2013/10/27:21:35:34 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:21:35:47 ahmet naim AHMETNAIM PageOpen FullProgressDialog
2013/10/27:21:35:47 ahmet naim AHMETNAIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\ahmet naim\Desktop\Autocad 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/10/27:21:35:47 ahmet naim AHMETNAIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=193
2013/10/27:21:35:48 ahmet naim AHMETNAIM PageOpen InstallCompleteDialog
2013/10/27:21:36:01 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:37:02 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:37:02 ahmet naim AHMETNAIM Launch
2013/10/27:21:37:06 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:37:03 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:37:03 ahmet naim AHMETNAIM Launch
2013/10/27:21:37:06 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:21:37:14 ahmet naim AHMETNAIM PageOpen BeginDeploymentDialog
2013/10/27:21:37:18 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:21:37:23 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:21:37:23 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:21:37:27 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:21:37:27 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:21:37:32 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:38:03 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:38:03 ahmet naim AHMETNAIM Launch
2013/10/27:21:38:06 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:38:04 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:38:04 ahmet naim AHMETNAIM Launch
2013/10/27:21:38:06 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:21:38:07 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:21:38:11 ahmet naim AHMETNAIM PageOpen ProductInfoDialog
2013/10/27:21:38:53 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:21:39:06 ahmet naim AHMETNAIM PageOpen FullProgressDialog
2013/10/27:21:39:06 ahmet naim AHMETNAIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\ahmet naim\Desktop\Autocad 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/10/27:21:39:06 ahmet naim AHMETNAIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=193
2013/10/27:21:40:40 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:40:40 ahmet naim AHMETNAIM Launch
2013/10/27:21:40:40 ahmet naim AHMETNAIM An instance of setup is already running. Only one instance of setup can run at a time.2013/10/27:21:40:42 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:39:07 ahmet naim AHMETNAIM PageOpen InstallCompleteDialog
2013/10/27:21:40:44 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:44:44 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:44:44 ahmet naim AHMETNAIM Launch
2013/10/27:21:44:47 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:44:45 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:44:45 ahmet naim AHMETNAIM Launch
2013/10/27:21:44:46 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:21:44:50 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:21:44:53 ahmet naim AHMETNAIM PageOpen ProductInfoDialog
2013/10/27:21:46:54 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:21:46:57 ahmet naim AHMETNAIM PageOpen FullProgressDialog
2013/10/27:21:46:57 ahmet naim AHMETNAIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\ahmet naim\Desktop\Autocad 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/10/27:21:46:57 ahmet naim AHMETNAIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=193
2013/10/27:21:46:57 ahmet naim AHMETNAIM PageOpen InstallCompleteDialog
2013/10/27:21:52:08 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:52:23 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:52:23 ahmet naim AHMETNAIM Launch
2013/10/27:21:52:27 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:52:24 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:52:24 ahmet naim AHMETNAIM Launch
2013/10/27:21:52:26 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:21:54:38 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:59:11 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:59:11 ahmet naim AHMETNAIM Launch
2013/10/27:21:59:14 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:21:59:12 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:21:59:12 ahmet naim AHMETNAIM Launch
2013/10/27:21:59:14 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:21:59:21 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:21:59:26 ahmet naim AHMETNAIM PageOpen ProductInfoDialog
2013/10/27:21:59:52 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:21:59:54 ahmet naim AHMETNAIM PageOpen FullProgressDialog
2013/10/27:21:59:54 ahmet naim AHMETNAIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\ahmet naim\Desktop\Autocad 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/10/27:21:59:54 ahmet naim AHMETNAIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=193
2013/10/27:21:59:54 ahmet naim AHMETNAIM PageOpen InstallCompleteDialog
2013/10/27:22:00:00 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:01:44 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:01:44 ahmet naim AHMETNAIM Launch
2013/10/27:22:01:46 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:01:45 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:01:45 ahmet naim AHMETNAIM Launch
2013/10/27:22:01:46 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:22:01:47 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:22:01:50 ahmet naim AHMETNAIM PageOpen ProductInfoDialog
2013/10/27:22:02:21 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:22:02:23 ahmet naim AHMETNAIM PageOpen FullProgressDialog
2013/10/27:22:02:23 ahmet naim AHMETNAIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\ahmet naim\Desktop\Autocad 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/10/27:22:02:23 ahmet naim AHMETNAIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=193
2013/10/27:22:02:23 ahmet naim AHMETNAIM PageOpen InstallCompleteDialog
2013/10/27:22:05:17 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:05:21 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:05:21 ahmet naim AHMETNAIM Launch
2013/10/27:22:05:24 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:05:22 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:05:22 ahmet naim AHMETNAIM Launch
2013/10/27:22:05:24 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:22:05:26 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:22:05:29 ahmet naim AHMETNAIM PageOpen ProductInfoDialog
2013/10/27:22:06:02 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:22:06:04 ahmet naim AHMETNAIM PageOpen FullProgressDialog
2013/10/27:22:06:04 ahmet naim AHMETNAIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\ahmet naim\Desktop\Autocad 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/10/27:22:06:04 ahmet naim AHMETNAIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=193
2013/10/27:22:06:04 ahmet naim AHMETNAIM PageOpen InstallCompleteDialog
2013/10/27:22:06:13 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:07:37 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:07:37 ahmet naim AHMETNAIM Launch
2013/10/27:22:07:39 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:07:38 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:07:38 ahmet naim AHMETNAIM Launch
2013/10/27:22:07:39 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:22:07:41 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:22:07:44 ahmet naim AHMETNAIM PageOpen ProductInfoDialog
2013/10/27:22:08:00 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:22:08:06 ahmet naim AHMETNAIM PageOpen FullProgressDialog
2013/10/27:22:08:06 ahmet naim AHMETNAIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\ahmet naim\Desktop\Autocad 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/10/27:22:08:06 ahmet naim AHMETNAIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=193
2013/10/27:22:08:06 ahmet naim AHMETNAIM PageOpen InstallCompleteDialog
2013/10/27:22:13:15 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:18:13 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:18:13 ahmet naim AHMETNAIM Launch
2013/10/27:22:18:15 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:18:14 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:18:14 ahmet naim AHMETNAIM Launch
2013/10/27:22:18:15 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:22:19:01 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:22:19:04 ahmet naim AHMETNAIM PageOpen ProductInfoDialog
2013/10/27:22:19:30 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:22:19:33 ahmet naim AHMETNAIM PageOpen FullProgressDialog
2013/10/27:22:19:33 ahmet naim AHMETNAIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\ahmet naim\Desktop\Autocad 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/10/27:22:19:33 ahmet naim AHMETNAIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=193
2013/10/27:22:19:34 ahmet naim AHMETNAIM PageOpen InstallCompleteDialog
2013/10/27:22:28:21 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:33:51 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:33:51 ahmet naim AHMETNAIM Launch
2013/10/27:22:33:53 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:33:52 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:33:52 ahmet naim AHMETNAIM Launch
2013/10/27:22:33:53 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:22:33:54 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:22:33:58 ahmet naim AHMETNAIM PageOpen ProductInfoDialog
2013/10/27:22:34:18 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:22:34:20 ahmet naim AHMETNAIM PageOpen FullProgressDialog
2013/10/27:22:34:20 ahmet naim AHMETNAIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\ahmet naim\Desktop\Autocad 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/10/27:22:34:20 ahmet naim AHMETNAIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=193
2013/10/27:22:34:20 ahmet naim AHMETNAIM PageOpen InstallCompleteDialog
2013/10/27:22:36:08 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:43:32 ahmet naim AHMETNAIM === Setup started on AHMETNAIM by ahmet naim ===
2013/10/27:22:43:32 ahmet naim AHMETNAIM Launch
2013/10/27:22:43:34 ahmet naim AHMETNAIM === Setup ended ===
2013/10/27:22:43:34 ahmet naim AHMETNAIM PageOpen LaunchDialog
2013/10/27:22:43:35 ahmet naim AHMETNAIM PageOpen LicenseDialog
2013/10/27:22:43:37 ahmet naim AHMETNAIM PageOpen ProductInfoDialog
2013/10/27:22:44:16 ahmet naim AHMETNAIM PageOpen ProductSelectionDialog2
2013/10/27:22:44:18 ahmet naim AHMETNAIM PageOpen FullProgressDialog
2013/10/27:22:44:18 ahmet naim AHMETNAIM Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\ahmet naim\Desktop\Autocad 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/10/27:22:44:18 ahmet naim AHMETNAIM Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=193
5 REPLIES 5
david.lau
in reply to: toxxxteth
Please check your TEMP folder for a clue on why the C++ component didn't install.  A sample log is below:
http://upandready.typepad.com/files/microsoft-visual-c-2010-x86-redistributable-setup_20120110_13125...
You can try the following:
http://upandready.typepad.com/up_and_ready/2012/09/error-1603-microsoft-visual-c-2005-sp1-redistribu...
Also, you can unninstall the 2010 C++ components via the Control Panel and try the installation of the software again.
David Lau
toxxxteth
in reply to: david.lau
Hello David,
I tried the things in your link but i am still getting the same result. Also i deleted all the C++ versions..and tried again..
i couldnt find any log file in my temp folder besides..Can you please guide me to find the installation guide that you attached in your post?
the things that i couldn't get;
1-which version of C++ should we install ? 2005, 2008, 2010, 2013?
2-i am using windows 8 x64..why this installation is interested with x86 of VCRedist although there is x64 folder in 3rdParty folder ?
i opened x64 setup manually and installed then opened the software installation but it didnt work as well.
toxxxteth
as i searched in microsoft's website.. i've opened installers log from registry editor..and change the value to "voicewarmupx"...i do not know if that is the log you sampled..but could not find anything in Temp folder after my try. i saw somewhere about "please install directx" so i installed/updated it - although i've already have it-..but still i am getting the same results in installation. looking forward your help..
dembkod
toxxxteth,
Hello. Did you uninstall all the C++ on your machine or just 2010? I would uninstall all eth 2005, 2008, and 2010 entries. Your log file explicitly states you are having an issue with a 2008 version. If you uninstalled a different year, you could be uninstalling around the problem. Just wanted to make sure you tried removing all the C++.
Thank you for taking part in our community!
David Dembkoski
toxxxteth
in reply to: dembkod
hello David,
I've installed all components of all versions and then tried..i also installed only 2008/2010 and tried one by one but couldnt make it again..Finally i installed Autocad 2014, and it is working now. i dont know how..thanks for your support still..
Administrator Productivity
