After the launcher installed autocad 2015, it then said it had failed to install it and several other things. I then tried to reinstall through the online autocad account manager but when the files finishes downloading and then run, it stops immediately and gives an error 8. I have tried to find the autocad program in the control panel to uninstall but it does not appear there and using the windows fixit tool doesnt find it either. Any suggestions to do so?
Looks like you are facing issuse in download the software properly kindly download via virtual agent
See below screencast for the same
But would I be able to do the virtual agent or some other download way if I have the student version of autocad? It does not give me nother option on how to download.
Give a try & see if it works or not.
Also if you are find any issuses with Education version of sofware you can register case here
