Installation & Licensing
fail on install c3d 2013
3 REPLIES 3
tomarneson
458 Views, 3 Replies
Install failed 3 times, always at the same place. Attached find the setuplog and a screenshot of the install program.
3 REPLIES 3
TravisNave
in reply to: tomarneson
1601 is generally a problem with your Windows Installer itself.
This error occurs when the Microsoft Windows Installer Service has been corrupted on the system. The Windows Installer Service is considered a core component of some Windows operating systems.  If a core operating system component is corrupted, in some cases, the issue can only be addressed if the operating system itself is repaired or reinstalled.
Autodesk Forums:
tomarneson
in reply to: TravisNave
My OS is WindowsXP Media Center Edition Version 2002 SP3. I'd rather not reinstall the OS. Is there a workaround?
tomarneson
I tried again after downloading an installer from MS and downloading C3D 2013 (AutoCAD_Civil3D_2013_English_Win_32bit.exe) again. No Joy! it failed at the same spot. I've attached the setup log, which has all the install logs.
I'd really like feedback from Autodesk on how to fix this problem.
Administrator Productivity
