All,
Is it possible to run the Factory Design Suite 2014 on a Mac? Are there certain programs from the suite that are okay? Are certain versions of the suite supported? I didn't see anything that said it was supported on the product page, but wanted to double check to see if anyone has had any success with this or if the suite is indeed supported, but just not labeled as such. If you have any questions, please do not hesitate to contact me. Hope all is well and have a most blessed day!
Peace,
Pete
Solved by DarrenP. Go to Solution.
you have to run windows on bootcamp or something similar on the mac to run it
DarrenP
DarrenP, just so I am sure I understand. The suite can be run on a Mac, with all the proper workflows, but you must have the Boot Camp (Leopard) set up on the Mac. Is this correct? Thanks in advance for your clarification!
yes
none of the products in the suite are MAC OS compatible they are only microsoft windows compatible
DarrenP
Thanks, DarrenP. I told my client to test it out first with the trial, but glad to know the proper method. Have a most blessed night!
