Installation & Licensing
Export Request Failed - Inventor 2010
3 REPLIES 3
msm
541 Views, 3 Replies
I was trying to export my license from my Inventor 2010 and import it to Inventor 2012 however I was unable to do it because of message at start (below). What should I do?
Tags (2)
3 REPLIES 3
TravisNave
in reply to: msm
You cannot export a license from one release into a newer release.  You simply need to activate your 2012 seat.  If you are under Subscription, this shouldn't be a problem.
Autodesk Forums:
msm
in reply to: msm
Thanks for your reply, so still do I need new serial number to activate product?
TravisNave
in reply to: msm
You will need your valid 2012 serial number.
Autodesk Forums:
Administrator Productivity
