Hi all,
Anyone know why it is not possible export a 2010 3ds License to another pc?
Message:
"Export Request Failed"
"The Serial number you entered is not valid. try again."
Buuuuut....the serial it is correct.
Solved by emily.xu. Go to Solution.
If the serial is under subscription, it may have been superceded with a new serial when the new release was issued. Given that its a 2010 release, this have happened several times.
I think your SN maybe upgraded to a new version, so you will no longer to export the license. The easy way to solve the problem is just install the product on your new machine, and activate it.
