Installation & Licensing
New Member
ACADChick
Message 11 of 16 (959 Views)
Re: Expired License
11-01-2012 05:27 AM in reply to: emily.xu
Thanks for the fix but it didn't work for me. I'm guessing it didn't work because the license system (Flex?) thinks that the trial has indeed ended because I set the clock back (following an earlier suggestion).
There is another issue I'd like to report. After exiting the dialog that tells me that the Trial has ended, ASD acts like it's still loading -the startup splash screen is still up and I can hear my computer chugging away. After a minute or two the splash screen does disappear and ASD no longer shows in the taskbar; HOWEVER the acad.exe process is still running and does not stop. I have to use the Task Manager to stop it.
New Member
MatthewMiller3886
Message 12 of 16 (929 Views)
Re: Expired License
11-02-2012 12:38 PM in reply to: mark.martin.se
I have been having the same issue.  I have never installed the program as a trial, and I am getting the same license expired message.  I tried this hotfix anyway, without success.  Any other ideas?
New Member
cranjawi
Message 13 of 16 (678 Views)
Re: Expired License
03-28-2013 12:23 AM in reply to: emily.xu
I have the same problem, downloaded the trial but says it has expired already when I try to open it. The hot fix is not for Mac. Any chance of a Mac hotfix? I can't find anyone to email my problem to being new to the AutoCad world.Any help would be greatly appreciated.
Valued Contributor
mohan_s
Message 14 of 16 (454 Views)
Re: Expired License
10-04-2013 03:43 AM in reply to: emily.xu
Dear all please download the hotfix from autodesk site the link is given below, please accept the solution if this solves the issue so that the other people come to know.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20784586&linkID=12952913
REgards
Mohan S.
Valued Contributor
mohan_s
Message 15 of 16 (454 Views)
Re: Expired License
10-04-2013 03:45 AM in reply to: emily.xu
Dear All please download the HOTFIX from the link given & read the readme.txt file for the process. Please accept this as solution if this solves the issue, sot hat other's comes to know this.
Regards
mohan Suryawanshi
Valued Contributor
mohan_s
Message 16 of 16 (452 Views)
Re: Expired License
10-04-2013 03:47 AM in reply to: mark.martin.se
Please download the HOTFIX from the link given and read the readme.txt file for the process. Accept this as a solution to let know others.
REgards
Mohan Suryawanshi
Autodesk Alert | We are currently working on restoring Previous Version License request access in the Autodesk Subscription Center. If you are a subscription customer and would like to request a Previous Version License, please use this link as a temporary workaround. We apologize for the inconvenience and thank you for your patience.
