Installation & Licensing
Everything loaded except the AutoCAD Civil 3D programs themselves. What now?
2 REPLIES 2
engtech
381 Views, 2 Replies
When I went to update from 2013 to the 2014, it uploaded everything but the actual programs themselves.  Why would it do this and what is the fix?
2 REPLIES 2
TravisNave
in reply to: engtech
Welcome to the community.
Your description seems confusing.  Did you only download 2014 but not actually install it yet?  Also, when you do install the new version, it does not replace the old versions.  You can continue to run 2013 side-by-side with 2014.
Please clarify.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
byron.morales
in reply to: TravisNave
Hello Engtech,
Please re-download the 2014 installation files as follows:
Lets try to use our new virtual agent called Matthew as follows:
1.       Go to http://www.autodesk.com
2.       Click on Contact Us
3.       Click on Customer Service
4.       Click on Virtual Agent
5.       Once the Virtual Agent opens:
Select the 5th Choice "Downloading and Installation"
Now select 1st choice "Software Download links"
Now select the 3rd choice "I need to re-download my product"
Select your product
You are now presented with the choice to download your software.
After the download completes, please reboot the computer, Turn
Antivirus Off, Clear the contents
of the %temp% folder and then attempt to re-install the software.
Let us know the Results.
Byron M.
Administrator Productivity
