Installation & Licensing
Message 1 of 1
88 Views, 0 Replies
Error
Hey guys,I have some problem with Maya student installation.One month ago i installed the try version of Maya, but one day ago trial time has expired so i have created a student account.I downloaded the Maya .exe a lot of time but it give me a lot of error.When i start to install it give me the image errors...And this is the lg file:
2014/7/25:14:48:02 CrackersMan CRACKERMAN PageOpen InstallCompleteDialog
2014/7/25:14:56:18 CrackersMan CRACKERMAN === Setup ended ===
2014/7/25:15:00:15 CrackersMan CRACKERMAN === Setup started on CRACKERMAN by CrackersMan ===
2014/7/25:15:00:15 CrackersMan CRACKERMAN Path_Length: 143
2014/7/25:15:00:15 CrackersMan CRACKERMAN Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/25:15:00:15 CrackersMan CRACKERMAN Launch
2014/7/25:15:00:15 CrackersMan CRACKERMAN CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-48766069 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/25:15:00:15 CrackersMan CRACKERMAN Current Directory C:\Users\CRACKE~1\AppData\Local\Temp\_AID131.tmp
2014/7/25:15:00:59 CrackersMan CRACKERMAN === Setup ended ===
2014/7/25:15:00:16 CrackersMan CRACKERMAN === Setup started on CRACKERMAN by CrackersMan ===
2014/7/25:15:00:16 CrackersMan CRACKERMAN Path_Length: 143
2014/7/25:15:00:16 CrackersMan CRACKERMAN Current Directory C:\Users\CRACKE~1\AppData\Local\Temp\_AID131.tmp
2014/7/25:15:00:16 CrackersMan CRACKERMAN Launch
2014/7/25:15:00:17 CrackersMan CRACKERMAN Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/25:15:00:59 CrackersMan CRACKERMAN Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/25:15:00:59 CrackersMan CRACKERMAN PageOpen LaunchDialog
2014/7/25:15:01:59 CrackersMan CRACKERMAN PageOpen LicenseDialog
2014/7/25:15:01:59 CrackersMan CRACKERMAN PageOpen ProductInfoDialog
2014/7/25:15:01:59 CrackersMan CRACKERMAN PageOpen ProductSelectionDialog2
2014/7/25:15:02:01 CrackersMan CRACKERMAN PageOpen FullProgressDialog
2014/7/25:15:02:02 CrackersMan CRACKERMAN Download Play VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/7/25:15:02:16 CrackersMan CRACKERMAN Download Complete VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/7/25:15:02:16 CrackersMan CRACKERMAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/7/25:15:02:17 CrackersMan CRACKERMAN Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/7/25:15:02:18 CrackersMan CRACKERMAN Download Error Connection has expired. Please reconnect to site. VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/25:15:02:18 CrackersMan CRACKERMAN Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Download Failed, Installation aborted, Result=1603
2014/7/25:15:02:18 CrackersMan CRACKERMAN Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/7/25:15:02:18 CrackersMan CRACKERMAN PageOpen InstallCompleteDialog
2014/7/25:15:02:31 CrackersMan CRACKERMAN === Setup ended ===
2014/7/25:15:03:48 CrackersMan CRACKERMAN === Setup started on CRACKERMAN by CrackersMan ===
2014/7/25:15:03:48 CrackersMan CRACKERMAN Path_Length: 143
2014/7/25:15:03:48 CrackersMan CRACKERMAN Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/25:15:03:48 CrackersMan CRACKERMAN Launch
2014/7/25:15:03:48 CrackersMan CRACKERMAN CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-48766069 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/25:15:03:48 CrackersMan CRACKERMAN Current Directory C:\Users\CRACKE~1\AppData\Local\Temp\_AI10AD.tmp
2014/7/25:15:03:50 CrackersMan CRACKERMAN === Setup ended ===
2014/7/25:15:03:49 CrackersMan CRACKERMAN === Setup started on CRACKERMAN by CrackersMan ===
2014/7/25:15:03:49 CrackersMan CRACKERMAN Path_Length: 143
2014/7/25:15:03:49 CrackersMan CRACKERMAN Current Directory C:\Users\CRACKE~1\AppData\Local\Temp\_AI10AD.tmp
2014/7/25:15:03:49 CrackersMan CRACKERMAN Launch
2014/7/25:15:03:50 CrackersMan CRACKERMAN Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/25:15:03:50 CrackersMan CRACKERMAN PageOpen LaunchDialog
2014/7/25:15:03:54 CrackersMan CRACKERMAN PageOpen LicenseDialog
2014/7/25:15:03:54 CrackersMan CRACKERMAN PageOpen ProductInfoDialog
2014/7/25:15:03:54 CrackersMan CRACKERMAN PageOpen ProductSelectionDialog2
2014/7/25:15:03:55 CrackersMan CRACKERMAN PageOpen FullProgressDialog
2014/7/25:15:03:55 CrackersMan CRACKERMAN Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/7/25:15:03:55 CrackersMan CRACKERMAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/7/25:15:03:56 CrackersMan CRACKERMAN Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/7/25:15:03:57 CrackersMan CRACKERMAN Download Error Connection has expired. Please reconnect to site. VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/25:15:03:57 CrackersMan CRACKERMAN Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Download Failed, Installation aborted, Result=1603
2014/7/25:15:03:57 CrackersMan CRACKERMAN Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/7/25:15:13:06 CrackersMan CRACKERMAN === Setup started on CRACKERMAN by CrackersMan ===
2014/7/25:15:13:06 CrackersMan CRACKERMAN Path_Length: 143
2014/7/25:15:13:06 CrackersMan CRACKERMAN Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/25:15:13:06 CrackersMan CRACKERMAN Launch
2014/7/25:15:13:06 CrackersMan CRACKERMAN CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-48766069 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/25:15:13:06 CrackersMan CRACKERMAN Another Autodesk install/update is now occurring on this computer. Please wait for that to complete and then click Retry.2014/7/25:15:13:13 CrackersMan CRACKERMAN === Setup ended ===
2014/7/25:15:03:57 CrackersMan CRACKERMAN PageOpen InstallCompleteDialog
2014/7/25:15:13:17 CrackersMan CRACKERMAN === Setup ended ===
2014/7/25:15:13:53 CrackersMan CRACKERMAN === Setup started on CRACKERMAN by CrackersMan ===
2014/7/25:15:13:53 CrackersMan CRACKERMAN Path_Length: 143
2014/7/25:15:13:53 CrackersMan CRACKERMAN Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/25:15:13:53 CrackersMan CRACKERMAN Launch
2014/7/25:15:13:53 CrackersMan CRACKERMAN CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-48766069 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/25:15:13:53 CrackersMan CRACKERMAN Current Directory C:\Users\CRACKE~1\AppData\Local\Temp\_AI4C43.tmp
2014/7/25:15:13:54 CrackersMan CRACKERMAN === Setup ended ===
2014/7/25:15:13:54 CrackersMan CRACKERMAN Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/25:15:13:54 CrackersMan CRACKERMAN PageOpen LaunchDialog
2014/7/25:15:13:57 CrackersMan CRACKERMAN PageOpen LicenseDialog
2014/7/25:15:13:57 CrackersMan CRACKERMAN PageOpen ProductInfoDialog
2014/7/25:15:13:57 CrackersMan CRACKERMAN PageOpen ProductSelectionDialog2
2014/7/25:15:13:59 CrackersMan CRACKERMAN PageOpen FullProgressDialog
2014/7/25:15:13:59 CrackersMan CRACKERMAN Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/7/25:15:13:59 CrackersMan CRACKERMAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/7/25:15:14:00 CrackersMan CRACKERMAN Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/7/25:15:14:00 CrackersMan CRACKERMAN Download Error Connection has expired. Please reconnect to site. VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/25:15:14:00 CrackersMan CRACKERMAN Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Download Failed, Installation aborted, Result=1603
2014/7/25:15:14:00 CrackersMan CRACKERMAN Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/7/25:15:14:00 CrackersMan CRACKERMAN PageOpen InstallCompleteDialog
2014/7/25:15:14:12 CrackersMan CRACKERMAN === Setup ended ===
2014/7/25:15:15:15 CrackersMan CRACKERMAN === Setup started on CRACKERMAN by CrackersMan ===
2014/7/25:15:15:15 CrackersMan CRACKERMAN Path_Length: 143
2014/7/25:15:15:15 CrackersMan CRACKERMAN Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/25:15:15:15 CrackersMan CRACKERMAN Launch
2014/7/25:15:15:15 CrackersMan CRACKERMAN CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-48766069 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/25:15:15:15 CrackersMan CRACKERMAN Current Directory C:\Users\CRACKE~1\AppData\Local\Temp\_AI8DDB.tmp
2014/7/25:15:15:16 CrackersMan CRACKERMAN === Setup ended ===
2014/7/25:15:15:16 CrackersMan CRACKERMAN === Setup started on CRACKERMAN by CrackersMan ===
2014/7/25:15:15:16 CrackersMan CRACKERMAN Path_Length: 143
2014/7/25:15:15:16 CrackersMan CRACKERMAN Current Directory C:\Users\CRACKE~1\AppData\Local\Temp\_AI8DDB.tmp
2014/7/25:15:15:16 CrackersMan CRACKERMAN Launch
2014/7/25:15:15:16 CrackersMan CRACKERMAN Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/25:15:15:16 CrackersMan CRACKERMAN PageOpen LaunchDialog
2014/7/25:15:15:19 CrackersMan CRACKERMAN PageOpen LicenseDialog
2014/7/25:15:15:19 CrackersMan CRACKERMAN PageOpen ProductInfoDialog
2014/7/25:15:15:19 CrackersMan CRACKERMAN PageOpen ProductSelectionDialog2
2014/7/25:15:15:21 CrackersMan CRACKERMAN PageOpen FullProgressDialog
2014/7/25:15:15:21 CrackersMan CRACKERMAN Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/7/25:15:15:21 CrackersMan CRACKERMAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/7/25:15:15:22 CrackersMan CRACKERMAN Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/7/25:15:15:22 CrackersMan CRACKERMAN Download Error Connection has expired. Please reconnect to site. VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/25:15:15:22 CrackersMan CRACKERMAN Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Download Failed, Installation aborted, Result=1603
2014/7/25:15:15:22 CrackersMan CRACKERMAN Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/7/25:15:15:22 CrackersMan CRACKERMAN PageOpen InstallCompleteDialog
2014/7/25:15:15:24 CrackersMan CRACKERMAN === Setup ended ===
2014/7/25:15:30:12 CrackersMan CRACKERMAN === Setup started on CRACKERMAN by CrackersMan ===
2014/7/25:15:30:12 CrackersMan CRACKERMAN Path_Length: 143
2014/7/25:15:30:12 CrackersMan CRACKERMAN Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/25:15:30:12 CrackersMan CRACKERMAN Launch
2014/7/25:15:30:12 CrackersMan CRACKERMAN CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-48766069 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/25:15:30:12 CrackersMan CRACKERMAN Current Directory C:\Users\CRACKE~1\AppData\Local\Temp\_AIAEA1.tmp
2014/7/25:15:30:13 CrackersMan CRACKERMAN === Setup ended ===
2014/7/25:15:30:13 CrackersMan CRACKERMAN Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/25:15:30:13 CrackersMan CRACKERMAN PageOpen LaunchDialog
2014/7/25:15:30:17 CrackersMan CRACKERMAN PageOpen LicenseDialog
2014/7/25:15:30:17 CrackersMan CRACKERMAN PageOpen ProductInfoDialog
2014/7/25:15:30:17 CrackersMan CRACKERMAN PageOpen ProductSelectionDialog2
2014/7/25:15:30:18 CrackersMan CRACKERMAN PageOpen FullProgressDialog
2014/7/25:15:30:19 CrackersMan CRACKERMAN Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/7/25:15:30:19 CrackersMan CRACKERMAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/7/25:15:30:20 CrackersMan CRACKERMAN Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/7/25:15:30:20 CrackersMan CRACKERMAN Download Error Connection has expired. Please reconnect to site. VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/25:15:30:20 CrackersMan CRACKERMAN Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Download Failed, Installation aborted, Result=1603
2014/7/25:15:30:20 CrackersMan CRACKERMAN Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/7/25:15:30:21 CrackersMan CRACKERMAN PageOpen InstallCompleteDialog
2014/7/25:15:30:24 CrackersMan CRACKERMAN === Setup ended ===
2014/7/25:15:32:52 CrackersMan CRACKERMAN === Setup started on CRACKERMAN by CrackersMan ===
2014/7/25:15:32:52 CrackersMan CRACKERMAN Path_Length: 143
2014/7/25:15:32:52 CrackersMan CRACKERMAN Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/25:15:32:52 CrackersMan CRACKERMAN Launch
2014/7/25:15:32:52 CrackersMan CRACKERMAN CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-48766069 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/25:15:32:52 CrackersMan CRACKERMAN Current Directory C:\Users\CRACKE~1\AppData\Local\Temp\_AI1F05.tmp
2014/7/25:15:32:53 CrackersMan CRACKERMAN === Setup ended ===
2014/7/25:15:32:53 CrackersMan CRACKERMAN Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/25:15:32:53 CrackersMan CRACKERMAN PageOpen LaunchDialog
2014/7/25:15:32:56 CrackersMan CRACKERMAN PageOpen LicenseDialog
2014/7/25:15:32:56 CrackersMan CRACKERMAN PageOpen ProductInfoDialog
2014/7/25:15:32:56 CrackersMan CRACKERMAN PageOpen ProductSelectionDialog2
2014/7/25:15:33:00 CrackersMan CRACKERMAN PageOpen FullProgressDialog
2014/7/25:15:33:01 CrackersMan CRACKERMAN Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/7/25:15:33:01 CrackersMan CRACKERMAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/7/25:15:33:01 CrackersMan CRACKERMAN Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/7/25:15:33:02 CrackersMan CRACKERMAN Download Error Connection has expired. Please reconnect to site. VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/25:15:33:02 CrackersMan CRACKERMAN Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Download Failed, Installation aborted, Result=1603
2014/7/25:15:33:02 CrackersMan CRACKERMAN Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/7/25:15:33:02 CrackersMan CRACKERMAN PageOpen InstallCompleteDialog
2014/7/25:18:37:18 CrackersMan CRACKERMAN === Setup ended ===
2014/7/27:23:12:28 CrackersMan CRACKERMAN === Setup started on CRACKERMAN by CrackersMan ===
2014/7/27:23:12:28 CrackersMan CRACKERMAN Path_Length: 143
2014/7/27:23:12:28 CrackersMan CRACKERMAN Current Directory C:\Autodesk\Autodesk_Maya_2015_wi_en-US
2014/7/27:23:12:28 CrackersMan CRACKERMAN Launch
2014/7/27:23:12:28 CrackersMan CRACKERMAN CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe" /SN 900-48766069 /PK 657G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/27:23:12:28 CrackersMan CRACKERMAN Current Directory C:\Users\CRACKE~1\AppData\Local\Temp\_AI9F6B.tmp
2014/7/27:23:13:49 CrackersMan CRACKERMAN === Setup ended ===
2014/7/27:23:12:30 CrackersMan CRACKERMAN Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/27:23:13:49 CrackersMan CRACKERMAN Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/SETUP_x64.t...
2014/7/27:23:13:49 CrackersMan CRACKERMAN PageOpen LaunchDialog
2014/7/27:23:16:09 CrackersMan CRACKERMAN PageOpen LicenseDialog
2014/7/27:23:16:09 CrackersMan CRACKERMAN PageOpen ProductInfoDialog
2014/7/27:23:16:09 CrackersMan CRACKERMAN PageOpen ProductSelectionDialog2
2014/7/27:23:16:11 CrackersMan CRACKERMAN PageOpen FullProgressDialog
2014/7/27:23:16:29 CrackersMan CRACKERMAN Download Play VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/7/27:23:17:48 CrackersMan CRACKERMAN Download Complete VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/{B8DFAAF4-0BCF-49DB-8F35-3B4ACD35CFA8}/VCREDIST201...
2014/7/27:23:17:48 CrackersMan CRACKERMAN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Maya 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/7/27:23:17:49 CrackersMan CRACKERMAN Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/7/27:23:17:51 CrackersMan CRACKERMAN Download Error Connection has expired. Please reconnect to site. VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/MAYA/WI/Autodesk_Maya_2015_wi_en-US_Setup.exe
2014/7/27:23:17:51 CrackersMan CRACKERMAN Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Download Failed, Installation aborted, Result=1603
2014/7/27:23:17:51 CrackersMan CRACKERMAN Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
0 REPLIES 0
Administrator Productivity
