Installation & Licensing
Error while installing 3ds max
1 REPLY 1
lucasg98
414 Views, 1 Reply
2013/7/7:00:21:14    Guthrie    GUTHRIE-PC    === Setup started on GUTHRIE-PC by Guthrie ===
2013/7/7:00:21:14    Guthrie    GUTHRIE-PC    Path_Length: 155
2013/7/7:00:21:14    Guthrie    GUTHRIE-PC    Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2014_EFGJKS_Win_64bit_wi_en-US
2013/7/7:00:21:14    Guthrie    GUTHRIE-PC    Launch
2013/7/7:00:21:14    Guthrie    GUTHRIE-PC    CommandLine    /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAXDES/WI/Autodesk_3ds_Max_Design_2014_EFGJKS_Wi... /SN 900-37056596 /PK 495F1 /student /skipEULA /akamai /auth  /sid
2013/7/7:00:21:14    Guthrie    GUTHRIE-PC    Current Directory C:\Users\Guthrie\AppData\Local\Temp\_AI6557.tmp
2013/7/7:00:21:24    Guthrie    GUTHRIE-PC    === Setup ended ===
2013/7/7:00:21:16    Guthrie    GUTHRIE-PC    === Setup started on GUTHRIE-PC by Guthrie ===
2013/7/7:00:21:16    Guthrie    GUTHRIE-PC    Path_Length: 155
2013/7/7:00:21:16    Guthrie    GUTHRIE-PC    Current Directory C:\Users\Guthrie\AppData\Local\Temp\_AI6557.tmp
2013/7/7:00:21:16    Guthrie    GUTHRIE-PC    Launch
2013/7/7:00:21:18    Guthrie    GUTHRIE-PC    Download    Skipped    SETUP_CONFIG    http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}...
2013/7/7:00:21:23    Guthrie    GUTHRIE-PC    PageOpen    LaunchDialog
2013/7/7:00:21:32    Guthrie    GUTHRIE-PC    PageOpen    LicenseDialog
2013/7/7:00:21:32    Guthrie    GUTHRIE-PC    PageOpen    ProductInfoDialog
2013/7/7:00:21:32    Guthrie    GUTHRIE-PC    PageOpen    ProductSelectionDialog2
2013/7/7:00:21:34    Guthrie    GUTHRIE-PC    PageOpen    FullProgressDialog
2013/7/7:00:21:35    Guthrie    GUTHRIE-PC    Download    Skipped    VCREDIST2005SP1ATLX86    http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}...
2013/7/7:00:21:35    Guthrie    GUTHRIE-PC    Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Guthrie\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/7/7:00:21:44    Guthrie    GUTHRIE-PC    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1603
Any clue whats going on?
1 REPLY 1
TravisNave
in reply to: lucasg98
Yes.
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
The prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
