2013/7/7:00:21:14 Guthrie GUTHRIE-PC === Setup started on GUTHRIE-PC by Guthrie ===
2013/7/7:00:21:14 Guthrie GUTHRIE-PC Path_Length: 155
2013/7/7:00:21:14 Guthrie GUTHRIE-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_Design_2014_EFGJKS_Win_64bit_wi_en-US
2013/7/7:00:21:14 Guthrie GUTHRIE-PC Launch
2013/7/7:00:21:14 Guthrie GUTHRIE-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAXDES/WI/Autodesk_3ds_Max_Design_2014_EFGJKS_Wi... /SN 900-37056596 /PK 495F1 /student /skipEULA /akamai /auth /sid
2013/7/7:00:21:14 Guthrie GUTHRIE-PC Current Directory C:\Users\Guthrie\AppData\Local\Temp\_AI6557.tmp
2013/7/7:00:21:24 Guthrie GUTHRIE-PC === Setup ended ===
2013/7/7:00:21:16 Guthrie GUTHRIE-PC === Setup started on GUTHRIE-PC by Guthrie ===
2013/7/7:00:21:16 Guthrie GUTHRIE-PC Path_Length: 155
2013/7/7:00:21:16 Guthrie GUTHRIE-PC Current Directory C:\Users\Guthrie\AppData\Local\Temp\_AI6557.tmp
2013/7/7:00:21:16 Guthrie GUTHRIE-PC Launch
2013/7/7:00:21:18 Guthrie GUTHRIE-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}...
2013/7/7:00:21:23 Guthrie GUTHRIE-PC PageOpen LaunchDialog
2013/7/7:00:21:32 Guthrie GUTHRIE-PC PageOpen LicenseDialog
2013/7/7:00:21:32 Guthrie GUTHRIE-PC PageOpen ProductInfoDialog
2013/7/7:00:21:32 Guthrie GUTHRIE-PC PageOpen ProductSelectionDialog2
2013/7/7:00:21:34 Guthrie GUTHRIE-PC PageOpen FullProgressDialog
2013/7/7:00:21:35 Guthrie GUTHRIE-PC Download Skipped VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAXDES/WI/{9842D110-A6F8-4DF3-8825-CF95386E15CE}...
2013/7/7:00:21:35 Guthrie GUTHRIE-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max Design 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Guthrie\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/7/7:00:21:44 Guthrie GUTHRIE-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
Any clue whats going on?
Yes.
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
The prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
