Installation & Licensing
Error while creating the network deployment of Revit MEP 2011 x64
4 REPLIES 4
449 Views, 4 Replies
Here is an error I am getting while trying to create the network install for Revit MEP 2011 x64.  I have had no issues with any other 64 bit install.  I have downloaded the install from the subscription center twice with no luck.  Any suggestions?
4 REPLIES 4
DouglasLauritsen
This has been resolved for other users by clearing out old files in the Temp folder. Type %TEMP% in the address bar of Windows Explorer to go to the location the Installer is using as the Temp folder. Delete everything you can that is older than the last few days or since before the last reboot.
Also try copying the DVD to the local hard drive and run the Deployment Wizard from the hard drive.
Douglas Lauritsen, Autodesk Product Support
Douglas Lauritsen
Support Specialist
Product Support
in reply to: DouglasLauritsen
I had no luck recreating the install point after deleting all temp cache.  Itried another 64 bit program and had no issues creating the install point for it.
Any suggestions?
THanks
DouglasLauritsen
Can you post the log files? There will be several files in %temp% that are named something like Autodesk Revit * 2011.log
Are there any Windows Application Event logs?
You might need to download the install files from a different computer or location as problems like this are often install source or media problems.
You can browse to %temp% by typing it in the Address bar of Windows Explorer.
Douglas Lauritsen
Support Specialist
Product Support
Douglas-
I have it fixed.  Everything in the log file was saying that the bulld was successfully built (which I know it wasnt).  I went ahead and deleted all temp files and even deleted my build on the server and now it seems to be working.
Thanks for all your help.
Felix
Administrator Productivity
