Installation & Licensing
Error when starting Maya 2013
5 REPLIES 5
dominik.scholz
2412 Views, 5 Replies
Hey, i downloaded the students version of Maya 2013, when i try to run it, a windows error appears (0xc000007b). I am using Windows 7 64bit and mit graphics card is a nvidia GTX 560 TI.
I hope you can help me.
- Dominik
5 REPLIES 5
TravisNave
in reply to: dominik.scholz
Make sure you are running a WHQL certified driver from nvidia.com and then check out this link:
http://community.softimage.com/forum/autodesk-3ds-max/autodesk-3ds-max--3ds-max-design-2011/max-2011...
Autodesk Forums:
philip.s
Hi Dominik,
Have you tried the suggestions mentioned in the following forum posts?
The application was unable to start correctly (0xc000007b) - LINK 1
The application was unable to start correctly (0xc000007b) - LINK 2
Additionally, your graphics card isn't on the Certified Hardware list for Maya 2013 and as such may be the culprit.
thanks, but i tried out all the links, no one helped... Smiley Sad
philip.s
Shucks! As mentioned earlier, it could very well be the graphics card...
I have been using the student version for three (3) months and now all of a sudden I am getting this message: Application unable to start correctly (oxc000007b) click ok to close the application.  Why now if it's my graphics card?
Administrator Productivity
