Hi I have AutoCAD 2008 LT installed which has recently developed a problem where when I click the Icon or File Icons nothing happens!
I tried all the repair & reinstall options from the control panel but this did not resolve the problem.
I decided to completely uninstall and reinstall from the CD but it will not let me and comes up with the following error:
Help please!! I'm stuck without CAD!
Joe
Maybe something wrong with your .Net Framework 2.0. When run the layer Manager, toolbar or menu, etc. will need .Net Framework. If it not run correctly, you will met the problem, so I would suggest you to uninstall or repair .Net Framework 2.0 first, then AutoCAD, when you install AutoCAD , .Net Framework will be installed also.
It will not open at all to see if the layers or toolbar manager works....should i try reinstalling the .NET framework 2.0 from Microsoft?
YES. If something wrong with .net framework, you will unable to use layers or toolbars, ect. so you need to repair or uninstall-reinstall .net framework 2.0 from Microsoft websit.
