Hello everyone, I've made a post here few weeks ago saying that my 3ds Max wasn't opening. Suddenly, the problem was gone and I was able to use it again. Then, last week, it stoped working again, with no aparent reasons. So I tried to install the 2013 version (I was using the 2014). It worked for a while, but now it's giving the same problem. I really need to use it for my classes, and I can't find a solution.
I have an Asus N46V
Windows 8 64bits
Nvidia Geforce GT 630M 2GB
Thanks in advance!
Start by doing a clean install of this driver:
http://www.nvidia.com/object/notebook-win8-win7-64bit-320.49-whql-driver.html
Yes. Installing the driver clean (did you check that box?) should require a restart.
sorry, I haven't checked the box. But I did now, and i've already restart my computer. But 3ds max isn't working 😕
Is it the activation crash, by chance?
Again, my only recommendation then would be to try a system restore back to a point in time that you knew it was working. Possibly some Windows Update or another installed program has caused this issue...
System Restore is quick and it is reversible if it does not work.
Here are the instructions:
http://windows.microsoft.com/en-us/windows-8/restore-refresh-reset-pc
Good Luck!
