Presently on assignment in China.
Laptop crashed, used Win XP Pro in English, with all updates.
Reinstalled Win XP Pro in Chinese, with all upates. (No XP Pro in English available)
Cleared AutoCad from Programs on 😧
Have my original AutoCad 2004 disk, S/N and Auth code.
Installs fine, English selected, with S/N.
Upon run - Failed - error message: Unable to run AutoCad contact local reseller.
FATAL ERROR: Unhandled Access Violation Reading 0x7eef6048 Exception at 360088a0h.
Any ideas on how to fix?
Jay
There could be two major reasons behind the crash.
1. Corrupt AutoCAD Program Files
2. Corrupt Operating System Files/Hard Dirve
For the meantime I suggest you try opening AutoCAD in Disgnostic Mode as per the lonk below:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6453117&linkID=9240817
If it works fine in diagnostic mode,then some other program maybe conflicting with the application, else if could be a
corrupt installation of AutoCAD. If an Uninstall and Reinstall of AutoCAD fails, it could be the operating system causing the
crash and may need a reload.
It would be useful if you could also attach the screen shot of the error message
You coauld try cretaing another user (with Administrative/Full rights) to see if the application runs well.
Apparently, there has been one other issue reporting of the same error message while installing AutoCAD 2004 on
Windows XP Chinese in which it is mentioned that AutoCAD cannot run as intended under such circumstances.
Hi Vivek,
This really has me baffled. I even changed my RAM in case that was a problem.
I'm installing as an Administrator on my laptop only.
Have run every diagnostic tool possible to find the source of the error to no avail.
I've successfully installed AutoCAD 2004 in 4 different computers, all using Chinese XP Pro to test.
1 - new laptop
1 - 2 year old laptop
2 - 3+ year old desktops
Each loads and runs without a glitch, I can register and use any of them in English, load and edit previously created drawings before the crash and blue screen of death.
I'm waiting for a XP Pro disk in English, will install and see if that cures it, will reinstall XP Pro in Chinese as well.
Thanks for your help and patience - I'll keep you posted on my results.
Jay
