Installation & Licensing
dl.hutton
254 Views, 1 Reply
Error Messages
Just downloaded Autodesk Inventor 2014 yesterday.
When I opened the program for the first time today I got the following:
"VBA failed to initialize properly. Please restart Inventor."
I clicked the 'OK' button and the program opened.
When I tried to use the 'Video and Tutorials' button I got:
"VBA failed to initialize properly while opening file
C:\Users\Public\Document\Autodesk\Inventor
2014\Templates\English\Standard (in).ipt. File open will fail."
There is no error number listed in the message window.  What's wrong?  Do I need to reinstall again?  Any help or sugestions will be greatly appreciated.
D Hutton  😞
1 REPLY 1
TravisNave
in reply to: dl.hutton
Welcome to the community.
You might start here:
http://forums.autodesk.com/t5/Autodesk-Inventor-General/Vba-failed-to-initialize/td-p/3946054
You might also have some luck searching thru here:
http://usa.autodesk.com/adsk/servlet/u/gsearch/results?siteID=123112&catID=123155&id=2088334&qt=VBA+...
Good Luck!
Autodesk Forums:
Administrator Productivity
