Installation & Licensing
error message to install Revit and 3dsMax from Deisgn Suite Ultimate 2013
2 REPLIES 2
linkboy
474 Views, 2 Replies
When I try to install Revit from Building design suite Ultimate 2013, it has this error message"1: 5 2: adlmPITSetProductInformation failed. 3: 2."(error image attached) I do have Revit 2012 Architecture on the same machine and want keep it.
Then I tried 3dsMAx design and ran across the same issue. Installation log file for 3dsMAx attached.
Tags (1)
2 REPLIES 2
philip.s
in reply to: linkboy
Hi yhe36,
The "adlmPITRemoveProductInformation failed" message indicates a possible corruption in the "ProductInformation.pit" file, and the generally accepted solution to this problem is to manually remove the file and to repeat the installation process. With that being said you may need to temporarily remove your 2012 software in order to resolve the issue.
Please see the following threads for more information on the process.
PIT REMOVAL THREAD - LINK 1
PIT REMOVAL THREAD - LINK 2
linkboy
Anyway I can keep 2012 programs? It's hard to uninstall and reinstall. If I remove that file, all 2012s will stop working somehow. Thanks!
Administrator Productivity
