Installation & Licensing
New Member
danicad2013
Message 1 of 3 (949 Views)
error message in autocad 2013 instalation
949 Views, 2 Replies
02-12-2013 03:26 PM
hi friends, a have tried to install autocad 2013 without succes. always get me the same message " Installation finish.Some products not have been installed." in spanish: "instalacion finalizada. Algunos prductos no se han podido instalar". How i can solve this problem? I can´t found the solution. I spent three days.
I downloaded many versions including 64 bits version. Autocad is installing in windows 7 home premium. Can you help me?Thanks.
New Member
janetzicht
Message 2 of 3 (915 Views)
Re: error message in autocad 2013 instalation
02-13-2013 02:20 PM in reply to: danicad2013
I had the same problem in not installing all the programs, I believe I had different softwares that weren't installed propertly but the Autodesk 2013 didn't install properly. I got some advice from tech support to uninstall the software from the computer and then create a separate user account and then install program in that new account after uninstalling from other account. Turn off the antivirus program off. I have been unsuccessful at uninstalling it from my computer. I have tried to unistall the two programs: Autodesk 3ds Max Design 2013  64-bit and Autodesk Sync(only two programs on my computer) but have been unsuccessful. The Autodesk 3ds does nothing when I click on Uninstall/Repair. The Autodesk Sync brings up "There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor." I'm afraid that if I try to repair it will use up the 2nd installation leaving me with nothing. I'm afraid if I try to install before I uninstall from other account will not work.
I have tried to reach Tech Support again but apparently Tech Support doesn't come with the purchase of the software installation, only when purchase a subscription do you get Tech Support. I don't understand how I was able to get Tech Support the first time, unless it wasn't Tech Support. I think that is rather stupid and greedy on Autodesk's part and not providing 24/7 Tech Support only Monday-Friday from 9am-5pm MST.
Please let me know if you have any success in finding the solution because I need this software up and running in a week for school.
Janet
*Expert Elite*
TravisNave
Message 3 of 3 (882 Views)
02-14-2013 08:24 AM in reply to: danicad2013
Post the installation log file found in your %TEMP% folder.
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
